-   -   lost parking lights and emergency flasher function (http://forums.pelicanparts.com/porsche-924-944-968-technical-forum/657837-lost-parking-lights-emergency-flasher-function.html)
earlr85944 02-13-2012 10:19 AM
lost both parking lights (front and rear) and emergency flasher function, headlights and turn signals work, any ideas, im going through the schematics and am testing, no power at fuse 40 or 41...
the function where you place the turn signal on one side with the ignition off does work for each side, i replaced the headlight switch, checking the wires for power in and out....
earlr85944 02-13-2012 10:48 AM
no power out of steering column stalk, (PL), working now, just didnt want this to go on for too long
kmakovac 02-13-2012 11:01 AM
for what i see in schematic probably the problem is the light switch inself or the hazart switch.
Try to interchange also the G2 relay(relay 15) ans see the fusible 38 and 33
earlr85944 02-13-2012 05:54 PM
It was the steering column stalk, thanks for checking
