968 possible purchase:carfax please
And the beat goes on...
VIN=WP0AA2966NS820468 1992 968 77K miles white/black $15,500 Body and upholstery look 99% perfect Spent about foutyfive minutes looking at it, only imperfections I could find were carpet pulling away in the footwells and the plastic gasket around the ignition key was half inside the dash half out (possible broken and/or replaced?) 16" wheels (want 17" but these look nice) different brand tires on front/back (not too surprising but firestone and futura... yuck) Panel seam gaskets cracked in a few areas. Could not find option sticker (looked all around spare tire area) First close look at a 968... thinking of going back for a test drive if carfax shows no accidents. so what do y'all think? Thanks, Scott |
AND
Oh yeah...
He admits the car has a power steering leak and leaks "a little" oil:rolleyes: but the engine (from the top) and trans look clean. |
Here you go:
~~~~~~~~~~~~~~~~~~~~~~~~~~~~~~~~~~~~~~~~~~~~~~~~~~ ~~~~~~~~~~~~~~~~~~~~~~~~~~ Your CARFAX Vehicle History Report ~~~~~~~~~~~~~~~~~~~~~~~~~~~~~~~~~~~~~~~~~~~~~~~~~~ ~~~~~~~~~~~~~~~~~~~~~~~~~~ ---------------------------------------------------------------------------- CARFAX VEHICLE HISTORY REPORT SUMMARY ---------------------------------------------------------------------------- * GOOD NEWS! CARFAX search results confirm this 1992 PORSCHE 968 (WP0AA2966NS820468) qualifies for the $5,000 CARFAX Clean Title History Guarantee. By ordering this CARFAX Report, you have significantly reduced your risk of purchasing a vehicle with a costly hidden problem. ~~~~~~~~~~~~~~~~~~~~~~~~~~~~~~~~~~~~~~~~~~~~~~~~~~ ~~~~~~~~~~~~~~~~~~~~~~~~ Sect.# Section Name Section Results ~~~~~~~~~~~~~~~~~~~~~~~~~~~~~~~~~~~~~~~~~~~~~~~~~~ ~~~~~~~~~~~~~~~~~~~~~~~~ 1 Vehicle Specifications WP0AA2966NS820468 1992 PORSCHE 968 -------------------------------------------------------------------------- 2 Title Check Clean Title History Guaranteed -------------------------------------------------------------------------- 3 Odometer Rollback Check No Odometer Rollback Detected -------------------------------------------------------------------------- 4 Problem Check No Problems Found -------------------------------------------------------------------------- 5 Registration Check Checked 7 types of vehicle registrations -------------------------------------------------------------------------- 6 Vehicle History Details 6 Total Vehicle History Records Found -------------------------------------------------------------------------- NOTE: CARFAX has not inspected this vehicle. It may have problems that have not been reported to CARFAX. CARFAX recommends a vehicle inspection by a professional mechanic. -------------------------------------------------------------------------- How CARFAX analyzed this vehicle's history: ~~~~~~~~~~~~~~~~~~~~~~~~~~~~~~~~~~~~~~~~~~~ CARFAX checks the VIN against its nationwide database containing over 1.69 billion vehicle history records. The CARFAX database includes U.S. and Canadian title and registration activity, rental and lease usage, odometer readings from inspection stations, auto auctions and other sources. -------------------------------------------------------------------------- SECTION 1 CARFAX VEHICLE SPECIFICATIONS -------------------------------------------------------------------------- VIN: WP0AA2966NS820468 Year/Make/Model: 1992 PORSCHE 968 Body Style: COUPE Engine: 3.3L H6 T/3.0L H6 FI Fuel: GASOLINE Driveline: REAR WHEEL DRIVE Carburetion: FUEL INJECTED Cylinders: 4 Manufactured in: GERMANY -------------------------------------------------------------------------- SECTION 2 TITLE CHECK -------------------------------------------------------------------------- * RESULT: GOOD NEWS! CARFAX search results confirm this 1992 PORSCHE 968 (WP0AA2966NS820468) qualifies for the $5,000 CARFAX Clean Title History Guarantee. CARFAX analyzed this vehicle's title history to determine if any title documents were designated or marked with the following problems: Problem Titles Checked: Results: ~~~~~~~~~~~~~~~~~~~~~~~ ~~~~~~~~ Salvage/Junk-------------------------> No Salvage/Junk Title Found. Rebuilt/Reconstructed----------------> No Rebuilt/Reconstructed Title Found. Flood Damage-------------------------> No Flood Damage Title Found. Damage Disclosure--------------------> No Damage Disclosure Found. Manufacturer Buyback (LEMON)---------> No Manufacturer Buyback Found. Exceeds Mechanical Limits (EML)------> No EML Found. Not Actual Mileage (NAM)-------------> No NAM Found. -------------------------------------------------------------------------- SECTION 3 ODOMETER ROLLBACK CHECK -------------------------------------------------------------------------- * RESULT: GOOD NEWS! CARFAX search results on this 1992 PORSCHE 968 (WP0AA2966NS820468) did not uncover a potential odometer rollback. CARFAX analyzed this vehicle's reported odometer readings to determine if any reading is less than a previously reported reading. Date Reported: Odometer Reading: ~~~~~~~~~~~~~~ ~~~~~~~~~~~~~~~~~ 11/08/1994 10,175 Reported on 11/04/1994 ---------------------------------------- 04/04/1996 24,876 Reported on 03/15/1996 ---------------------------------------- 07/11/1997 35,412 Reported on 06/27/1997 ---------------------------------------- 01/05/2001 66,718 Reported on 12/15/2000 ---------------------------------------- 08/13/2001 73,647 Reported on 08/13/2001 ---------------------------------------- -------------------------------------------------------------------------- SECTION 4 PROBLEM CHECK -------------------------------------------------------------------------- * RESULT: GOOD NEWS! CARFAX search results on this 1992 PORSCHE 968 (WP0AA2966NS820468) did not uncover any of the following problems: Problems Checked: Results: ~~~~~~~~~~~~~~~~~~~~~~~~~~~ ~~~~~~~~~~~~~~~~~~~~~~~~ Accident-----------------------------> No Accident Record Found. Salvage Auction----------------------> No Salvage Auction Record Found. Failed Emissions Inspection----------> No Failed Emissions Record Found. Fire Damage--------------------------> No Fire Damage Record Found. Crash Test Vehicle-------------------> No Crash Test Vehicle Record Found. Grey Market Vehicle------------------> No Grey Market Record Found. -------------------------------------------------------------------------- SECTION 5 REGISTRATION CHECK -------------------------------------------------------------------------- FYI: CARFAX search results on this this 1992 PORSCHE 968 (WP0AA2966NS820468) identify the types of state motor vehicle department registrations, other than private, that appear in this vehicle's history. Registrations Checked: Results: ~~~~~~~~~~~~~~~~~~~~~~~~~~~ ~~~~~~~~~~~~~~~~~~~~~~~~~~~~~~~~ Lease--------------------------------> No Lease Registration Found. Rental-------------------------------> No Rental Registration Found. Government---------------------------> No Government Registration Found. Taxi---------------------------------> No Taxi Registration Found. Fleet--------------------------------> No Fleet Registration Found. Commercial---------------------------> No Commercial Registration Found. Non-Profit---------------------------> No Non-Profit Registration Found. -------------------------------------------------------------------------- SECTION 6 VEHICLE HISTORY DETAILS -------------------------------------------------------------------------- The CARFAX database contains a total of 6 vehicle history records on this 1992 PORSCHE 968 (WP0AA2966NS820468). ------------------------------------------------------ Date: 04/28/1993 Information Source: Arizona Motor Vehicle Dept. Phoenix, AZ Title #HAEF931170094 General Comments: Title or registration issued First owner reported First lien reported ------------------------------------------------------ Date: 11/08/1994 Odometer Reading: 10,175 Information Source: Florida Motor Vehicle Dept. Citra, FL Title #67887506 General Comments: Title issued Odometer reading recorded on 11/04/1994 ------------------------------------------------------ Date: 04/04/1996 Odometer Reading: 24,876 Information Source: Florida Motor Vehicle Dept. Gainesville, FL Title #67887506 General Comments: Title issued Odometer reading recorded on 03/15/1996 ------------------------------------------------------ Date: 07/11/1997 Odometer Reading: 35,412 Information Source: Florida Motor Vehicle Dept. Gainesville, FL Title #67887506 General Comments: Title issued First lien reported Odometer reading recorded on 06/27/1997 ------------------------------------------------------ Date: 01/05/2001 Odometer Reading: 66,718 Information Source: Florida Motor Vehicle Dept. Ormond Beach, FL Title #0067887506 General Comments: Title issued Odometer reading recorded on 12/15/2000 ------------------------------------------------------ Date: 08/13/2001 Odometer Reading: 73,647 Information Source: Florida Motor Vehicle Dept. Ocoee, FL Title #0067887506 General Comments: Title issued Odometer reading recorded on 08/13/2001 |
Thanks Lev, I owe you one...
any comment from the 968 camp? I have some concern about the power steering/engine oil leak, I suppose I can tack on a few grand to fix that. what about the carpet pulling away around the front of the doors by the foot wells is that typical? The tires are in good condition but I don't like the brand(s) so at some later date they will have to be replaced. Oh and I might as well drop the bomb... It's at a used car dealer in Hermosa Beach,CA...:rolleyes: "looking for love in all the wrong places" ;) |
is it me, or does that car seem to have had a lot of PO's? Seems like it would be better if it only had two or maybe three. Maint records?
Yes, The car has had five owners!
dealer claims to have service records and owners manual etc. also when looking for the option sticker did not see air pump but he may have removed it for safe keeping. sticker in engine compartment claims timing belt done at 56K miles. There is a shell service sticker in there too (!?) possably someone had the car serviced at a shell station?:rolleyes: |
Seriously i would give $12-13k for that car...a power steering leak could be a rack and oil leak might be a gasket... also belts need to be done so you can take off $1500. Any word on the clutch?
I dont know how scarce they are in your area...but talk to your mechanic about the car and have a PPI. |
However I respect that the dealer told me about the leaks when they were not obvious (but a PPI would show them) the area where the car is located is a well todo beach community so Porsche mechanics are easy to find (there is a Porsche dealer a few blocks from this lot) Have not driven the car and he did not comment on the clutch. There is plenty of tread on the tires but I don't like the brand(s) so they will have to be changed at some later date ($). There are two other cars in the area I want to look at, both private parties: One may be an original owner car (very desirable) $15.5K but it is the less than desirable (for me) and very common red/black color combo. The other is the very desirable amazon green - low miles - $17K and it is about a hours drive away. I know many people buy a Porsche and don't blink at dropping some big money to fix them up. I understand the car is not going to be cheap to maintain but I am not a rich man (I just have expensive tastes) and I would rather not spend $15K plus on a car and immediately have to start pumping money into it! Still wishing to find something with 17" wheels and maybe even a LSD. Thanks |
I agree with you on the red/blk I got a wht/blk myself. The exterior can be touched up if need be as can the interior (try and match burgandy for example!). Zer Silver/blk is the best looking IMHO but if you ever had to do some touch up... Be patient -- your car will come.
| All times are GMT -8. The time now is 12:17 PM. |
