-   -   What is this part called? (http://forums.pelicanparts.com/porsche-924-944-968-technical-forum/660194-what-part-called.html)
_ERIC 02-22-2012 05:22 PM
I got a little excited when taking the speedometer out today and broke this.
http://i42.tinypic.com/308iblh.jpg
It goes from the rear of the speedometer to the rear of the tach where it plugs in.
If it helps, I have an 83 with a manuel trans. If anyone has one, I'll be needing one! Thanks
FrenchToast 02-22-2012 05:37 PM
That is the magic mystery odometer fluid pump relay servo line cooling jacket assembly.
I have no clue, sorry. :D Is there a shift light in the speedometer? Not sure why the speedo would need to communicate with the tach electronically.....
Just wanted to post because I was wondering where in CT you are?
Good luck!
_ERIC 02-22-2012 05:44 PM
Thank you Jrboulder!
FrenchToast, Im in Bethany.
FrenchToast 02-22-2012 06:09 PM
Originally Posted by Jrboulder (Post 6576123)
Hall sensor 944-641-251-00
Isn't that what I said? ;)
Have a good evening!
