RaF944's Avatar
Sunroof help needed!!!
Hey guys... My sunroof doesnt move up and down...but i can here the Motor so thats not broken...Do I need new gears? If so can i change them myself and how much do they cost and how many are needed.
This is for my 968....
Rafal
1993 Porsche 968
85.5 Porsche 944
Old 04-20-2002, 01:42 PM
RaF944's Avatar
Unhappy
Anyone?
1993 Porsche 968
85.5 Porsche 944
Old 04-20-2002, 08:25 PM
Scott R's Avatar
You will need to remove the rear headliner, then open the gear boxes and inspect the gears. If when you open them little white plastic pieces fall all over the rear seats then get new gears. You will also need to then adjust the maximum travel distance on the sunroof motor buy adjusting the micro switches. If the gears are good, but not spinning then go after the cable, it may have broken inside the cable sheath.
2021 Model Y
2005 Cayenne Turbo
2012 Panamera 4S
1980 911 SC
1999 996 Cab
Old 04-21-2002, 11:41 AM
pschaars951's Avatar
Send a message via AIM to pschaars951
probably the gears, they are cheap and you can do it yourself (careful with the headliner, mine started to tear when I was taking it down)
-pete
was: '85 300 ZX, '87 944 NA
is: '90 944 s2 coupe
Old 04-21-2002, 03:57 PM
