-   -   O2 sensor wire and wiring (http://forums.pelicanparts.com/porsche-924-944-968-technical-forum/66489-o2-sensor-wire-wiring.html)
cliff 04-23-2002 11:15 AM
I am trying to hook up my Air/Fuel gauge. Does anyone know which wire going to the DME I can tap into. Also, where is a good place to ground ? At the sensor or right before the DME. This is for a 88 944 turbo. Anyone with such experience. Also, what is the best (easiest ) way to tap into a switched power supply such as ignition switch ?:confused:
