manual steering for 87 na?
Have a 87 944 na who's steering is leaking at the rack, & hoses to the res. Was thinking a manual rack would simplify things when it comes time to replace. Has anyone done this? All input is appreciated
Old 03-10-2012, 06:27 AM
FrenchToast's Avatar
Yes. You need a manual rack from an '83 or earlier 924/944, as they were not offered later than that. (Except on uber-rare clubsport or cup cars). Then you need the later tie rods. I think that's all, I don't remember.
Some people also de-power the power rack. The advantage of the manual rack is it has a bigger ratio making it easier to turn.
Someone surely will chime in with a complete shopping list for the conversion.
Be safe, cheers!
Old 03-10-2012, 08:29 AM
Toofah King Bad
Rasta Monsta's Avatar
924 rack will not work. You need an 83 rack, tie rods, and intermediate shaft (jointed shaft from the rack to the steering column).
» 1987 924S Turbo - Got Boost? «
"DETERMINATION. Sometimes cars test us to make sure we're worthy. Fix it." - alfadoc
Old 03-10-2012, 08:54 AM
9FF 9FF is offline
9FF's Avatar
You also need at least one new rack mount rubber. The RH side is definitely different.
Old 03-10-2012, 10:18 AM
You can also remove everything, grease the rack really well and install it with no pump/fluid. Theres a write up on how to do it somewhere out there. A manual rack and everything you need will set you back a serious chunk of change
Old 03-10-2012, 07:30 PM
Toofah King Bad
Or not. Just bought the complete setup for our race car for $125, plus a pair of Rabbit tie rods I got new for $15 each.
Old 03-11-2012, 09:45 AM
rasta's steering
Rasta, Can you give me info on steering set up for your race, sounds like what i'm looking for.
Thanx
Old 03-11-2012, 10:51 AM
