-   -   Having tailight issues! Driver side! (http://forums.pelicanparts.com/porsche-924-944-968-technical-forum/665040-having-tailight-issues-driver-side.html)
Porsche 924 03-12-2012 09:13 AM
Hey guys this weekend I got some more sockets for the tailights to add more visibility in the back. So I added the extra socket and spliced the wire and hooked em up together and for some reason it didn't work! And I tried several bulbs, I took one off the blinker and tried it and did not work, and put it back on the blinker socket and worked fine! So I removed the splice connection and bridge connection and now it won't work like that even. And the passenger side works. I have tried to do the mod on the pass side yet. Did I do something wrong? I checked all the fuses and they r all fine. So I unplugged the main connector and tested for power. And there is no power when I have driving lights on. Only blinker, brake, and reverse have power, but no driving lights. And it was workining perfectly fine before! What has happened!? How do I fix it??? Help!!
This is the connection I made.
http://i1184.photobucket.com/albums/...s/31d76821.jpg
Cocacolakidd 03-12-2012 10:55 AM
Sounds like you have disturbed/disconnected a wire when moving them around - Our older wires can come apart easier because of age. Check all wiring for continuity.
Maybe even your new blue splicer cut the wire so neither wire has power now.
Porsche 924 03-12-2012 10:59 AM
But my connection doesn't work AT ALL. Where should I check for this exactly??
mytrplseven 03-12-2012 11:01 AM
Where'd U get the sockets?
Porsche 924 03-12-2012 11:05 AM
Off of another 944. I got the light assembly at a swap meet.
Cocacolakidd 03-12-2012 11:08 AM
Take apart that new blue connector to see if the problem is in there - Next check that power wire with a volt/ohm meter to see if it still has power, check before the new blue splicer. If no power there check back further until you find power and the break.
Porsche 924 03-12-2012 12:18 PM
Yeah I tried. There's no power coming from the main wire anymore. I checked the main plug also and no power..how far does that wire go???
Cocacolakidd 03-12-2012 12:34 PM
Does the passenger side have power to the tail light ? If so you may have to splice in a wire from that side and run a new wire over to the driver's tail light.
Have you checked the bulbs yet ?? What if they are at fault ?
Porsche 924 03-12-2012 01:57 PM
Yes the passenger side works perfectly. That's actually not a bad idea! If everything else fails I will do that!
And yes I have. I used the same bulb as the blinker. I removed it from blinker slot and placed it in driving light spot and it doesn't work l, put it back on blinker slot and it works perfectly..
Porsche 924 03-12-2012 08:25 PM
Fixed! Turned out the plug itself was bad so I just cut it before the plug and direct connected it. And now it works! And I also got those T connector dealios. Check it out guys!
http://i1184.photobucket.com/albums/...s/e796f473.jpg
http://i1184.photobucket.com/albums/...s/e1753e7e.jpg
Compare:
http://i1184.photobucket.com/albums/...s/a64bfcf2.jpg
Now
http://i1184.photobucket.com/albums/...s/b4a01957.jpg
Cocacolakidd 03-12-2012 08:48 PM
that's better - Our 944's do look better with the extra lights back there.
Have pfun
old 924 03-12-2012 11:34 PM
love the look..good job..i have spear lights and am going to do the same thing as soon as i get my dame car started...
Porsche 924 03-13-2012 04:01 AM
that's better - Our 944's do look better with the extra lights back there.<br>
<br>
Have pfun
Yes a lot better. And don't forget to mention 924's! And I know this may sound a bit river cheesy or childish, but then again I am 16..and I'm entering it in shows a lot and I wanted to go strobe on the lights. So I added strobe lights in the fog lights and reverse lights. Just ask if u guys want to watch a vid. I have it all ready, just need to post it on here if wished upon.
