adrian jaye's Avatar
rear rumble noise
quickie
engine in neutral and running
1) does the torque tube turn ???
2) rumbling noise getting worse same condition
engine running and car driving (DOH !)
1) rumbling noise getting worse same condition
OR !!!
engine running and car driving ONLY
orginal thoughts could be low or incorrect gearbox oil or bearings
ideas
944 LUX (not mine) !!
cheers
The fear of God is the begining of wisdom <><
NotJustPorsche
Subscribe: notjustporsche-subscribe@yahoogroups.com
Old 04-22-2002, 03:54 PM
adrian jaye,
does mashing the clutch in have any effect?
If it quitens down then it's something behind the clutch.
Does it get worse around 3000 rpm?
I had this when torque tube went bad.
Since it does the the noise in nuetral, I would say the torque tube.
drew1
Old 04-23-2002, 12:47 AM
pschaars951's Avatar
Send a message via AIM to pschaars951
stooopid question:
whats a torque tube?
-pete
was: '85 300 ZX, '87 944 NA
is: '90 944 s2 coupe
Old 04-23-2002, 01:54 AM
it's that pipe withy the driveshaft inside, running from clutch to trans.
drew1
Old 04-25-2002, 03:24 PM
