Turn signal not working
This morning on the way to work I noticed that my left turn signal only works some time.
Background: I took apart everything over the winter and swapped the dash. While I had the signal stock off I shot some contact cleaner in there because it was not always returning itself after a turn and I thought this would help it. Well it did because it always returns itself, but now I have this issue. If I pull the stalk back to center and then put it down again it will sometimes work. Also if I pull it up slightly it will start to work as well so I think somehow it is travelling farther then it should and passing the contact point? Is there a way to adjust it or take the unit apart to clean/fix or should I just look for a replacement? Thanks Mark |
| All times are GMT -8. The time now is 09:52 AM. |
