Turn signal switch bouncing back to center
My turn signal arm keeps bouncing up to the centered position when put down to signal left turn. Functions properly when pushed up to signal right turn. Is this adjustable? Thanks.. Love the cars!
Some things just wear out. You can buy replacments on ebay. Make sure the year is compatible. If it's wrong, the horn contact on the ring track may not work.
It's the springs/contacts in the switch. Only thing you can do is replace the whole unit.
Thanks, that's what i figured.. Found a few choices out there.. What I really need to do is find the wiring gremlins in the 86 na i ve been letting sit too long.. not looking forward to that back ache.. enjoy the ride..
| All times are GMT -8. The time now is 01:04 PM. |
