LinkBack Thread Tools Rating: Thread Rating: 6 votes, 3.67 average.
I will pm you.
Mine should not be too hard to reach.
I need to pull the front splitter to fix/reinforce a mounting hole(I hit a steep driveway a little too fast and it ripped out the splitter mounting bolt back by the drivers side tire).
I need to pull the power steering pump for a rebuild.
I need to drop the A/C compressor because I pinched the wire that activates the A/C clutch between the compressor and the mount so now my A/C won't engage.
Since I'm going to have it partially disassembled, I may swap in the aluminum radiator I picked up and swap in all the new hoses I got as well.
The downside is if I take the time to do all that to my car, I am stealing time I need to be putting into helping my son rebuild the 914 he wants to drive to school this fall.
Too many cars and not enough time.
1971 914 First Car (SOLD)
1972 914 rust bucket (SOLD)
1986 944 Turbo (Murdered by a Chevy Truck on the freeway)
1990 944 S2 Cabriolet - Long term project
1971 914 - Long term project #2
Old 06-29-2018, 10:37 PM
  Pelican Parts Catalog | Tech Articles | Promos & Specials    Reply With Quote #3281 (permalink)
In the Fires of Hell.....
kdjones2000's Avatar
Here is the original thread on this:
Help Needed: Picture of hood release for Stock Turbo
I will update if for the dead picture links for posterity.
NASA/PCA Instructor: '88 951S - with LBE, Guru chips, 3Bar FPR, 1.3mm shimmed WG, 3120 lbs, 256 RWHP, 15 psig boost
1987 924S 944 SPEC racecar - '88 pistons/DME, short 5th
1987 944S - Restored salvage title, ready to live again
I can fix your late 944 Cruise Control module - PM for details
Old 06-30-2018, 05:17 AM
  Pelican Parts Catalog | Tech Articles | Promos & Specials    Reply With Quote #3282 (permalink)
Replace the AC/Heater control unit on the 968, nice to have AC again.
http://www.bvdmotorsports.com
Active Rennlist Member.
http://members.rennlist.com/racerbvd/
See blog for my For Sale & Wanted List.
http://www.914club.com/bbs2/index.php?automodule=blog&blogid=337&
Old 06-30-2018, 08:03 AM
  Pelican Parts Catalog | Tech Articles | Promos & Specials    Reply With Quote #3283 (permalink)
944 S2
944 S2's Avatar
New Denso compressor installed. New high pressure line. Receiver/dryer. Now to get it charged tomorrow.
Discovered a couple of o rings were cut on the oringinal compressor.
Old 07-02-2018, 07:23 PM
  Pelican Parts Catalog | Tech Articles | Promos & Specials    Reply With Quote #3284 (permalink)
944 S2
944 S2's Avatar
Pics to follow my AC fix.
Old 07-03-2018, 04:23 AM
  Pelican Parts Catalog | Tech Articles | Promos & Specials    Reply With Quote #3285 (permalink)
I sprayed these, which appear to have never been removed in 49 years, getting ready to pull the pedal assembly and rebuild it.
Ken
'69 911E
Old 07-03-2018, 06:15 AM
  Pelican Parts Catalog | Tech Articles | Promos & Specials    Reply With Quote #3286 (permalink)
I got the hood open.
I did not like the fuel line routing I did a few weeks back so I installed a different fuel line on the input side.
The previous install had a short fuel line with a 90 degree bend on each end between the damper and the fuel rail.
I replaced that with a single 45 degree angle connector so I can angle the fuel damper down out of the way of the hood and connected the other side of the damper to a line with a 180 degree swivel connector.
Old 07-12-2018, 08:49 PM
  Pelican Parts Catalog | Tech Articles | Promos & Specials    Reply With Quote #3287 (permalink)
Nothing too exciting. I put the sunroof vinyl back on, and spent more time trying to strip these infernal Fuchs
Old 07-13-2018, 07:25 PM
  Pelican Parts Catalog | Tech Articles | Promos & Specials    Reply With Quote #3288 (permalink)
944 S2
944 S2's Avatar
Confirmed the AC still works great. Drove to P2O. 944ís were well represented!
Old 07-21-2018, 01:42 PM
  Pelican Parts Catalog | Tech Articles | Promos & Specials    Reply With Quote #3289 (permalink)
Ac drain line was clogged, wet dry vac suck it out sucked it down
Old 07-21-2018, 07:43 PM
  Pelican Parts Catalog | Tech Articles | Promos & Specials    Reply With Quote #3290 (permalink)
Replaced the original flat passenger side mirror with a convex one to eliminate the blind spot. The convex mirror makes a huge difference - $20 for the mirror and $40 for the auto glass shop to put it in.
Could be the best $60 I've spent in a long time.
Old 07-30-2018, 06:47 PM
  Pelican Parts Catalog | Tech Articles | Promos & Specials    Reply With Quote #3291 (permalink)
GregD's Avatar
Worked on finishing my 7 & 8 15" fuchs. Gonna paint the inset black. Gotta be better than my 7" cookie cutters with one of them bent. My a.c. was blowing fuse 6 as soon as you turned on the switch. Had new compressor. Found 1 thread where a guy said a wire under the dash got hot and melted. After hours of searching, I found it. Now we have working a.c. again after 2 years.... moved the connectors to the open slot.
Sent from my SM-G920V using Tapatalk
Greg DeBord
PCA Member
73 914/6 conversion
83 944 (newest addition)
99 996 aero coupe
Old 07-30-2018, 07:02 PM
  Pelican Parts Catalog | Tech Articles | Promos & Specials    Reply With Quote #3292 (permalink)
I did the same a few weeks ago, and oh boy what a difference!
Today I built ramps because I don't have a paved place to leave the car on stands for the impending motor mount/timing belt/reseal job. Also tried to fix my broken speed sensor connector but ended up making it worse.
My Fuchs are on the way back from Rick Hartbrodt as of today as well. I'm painting them white, so they're coming to me anodized but not painted (he doesn't do custom colors anymore).
Old 07-30-2018, 07:53 PM
  Pelican Parts Catalog | Tech Articles | Promos & Specials    Reply With Quote #3293 (permalink)
Two things: 1) changed electrical seat switch and 2) ordered Cibie Z beam replica headlight units and Sylvania Ultra H4 bulbs. Loved the z beam pattern on a 924 that I used to own. Back then I think I installed off-road 60/100 watt bulbs. Toying with the idea now, but I'm concerned about overheating the wiring when the high beams are on.
Old 08-01-2018, 08:47 PM
  Pelican Parts Catalog | Tech Articles | Promos & Specials    Reply With Quote #3294 (permalink)
Patrick
pfarah's Avatar
Car's still in storage during garage construction... Although, my indie shop (where the car is stored) did drive her last Sat for @20 miles to keep her juices flowing!
What's real unfortunate is that I'm going in for knee surgery in 1.5 weeks so I'll be out of commission for at least a few weeks (or longer?).
1984 944 NA, constant tinkering
Old 08-02-2018, 05:06 PM
  Pelican Parts Catalog | Tech Articles | Promos & Specials    Reply With Quote #3295 (permalink)
AZ PCA Flight 41 Concours
First place in Street 924, 944, 968, 928 class.
I was the only one in Street 924, 944, 968, 928 class.
Old 11-03-2018, 06:15 PM
  Pelican Parts Catalog | Tech Articles | Promos & Specials    Reply With Quote #3296 (permalink)
Pauld_94S2's Avatar
Yeah, but I would have given you First Place regardless!
Good looking S2 Cab!
Old 11-04-2018, 08:59 AM
  Pelican Parts Catalog | Tech Articles | Promos & Specials    Reply With Quote #3297 (permalink)
Thanks Paul but you are biased.
According to the judges score sheets, my car is hideous. It actually had dirt in the gas filled compartment and grease on the door hinges. I should just take it to the crusher.
To be honest all of the judges told me how much they loved my car but in a concours EVERYTHING counts, every spec of dust, blade of grass, etc.
My header panel does not line up EXACTLY the same on the right and left so I got points off for that. I had non-Porsche items in my glove box, I got points off for that.
I did get beat up pretty bad on the scores for a lot of things but that is the nature of a concours.
Aside from the details required by the concours rules, all of the judges were extremely nice, complementary, and helpful especially since this was my very first concours.
Old 11-05-2018, 10:26 AM
  Pelican Parts Catalog | Tech Articles | Promos & Specials    Reply With Quote #3298 (permalink)
Bunch of interior stuff. Replacing headliner after fixing sunroof gears and rear hatch. Installing 3 speaker door cards with new speakers. Fixing passenger side power seat.
Old 11-08-2018, 05:18 AM
  Pelican Parts Catalog | Tech Articles | Promos & Specials    Reply With Quote #3299 (permalink)
Send a message via Skype™ to jtehfreaks
Just got my nasty looking fuel rail powder coated and replaced the front seals on my leaky camshaft.
1987 Black Porsche 944 N/A
Old 11-14-2018, 05:38 PM
  Pelican Parts Catalog | Tech Articles | Promos & Specials    Reply With Quote #3300 (permalink)
