Got back to work on my car's goal to lose weight for the new year.
Did the initial cleaning of my automatic transaxle so I can now work on it replacing al the seals,filters and clean up real good
curtisr
Decided to start my 924s yesterday as I do from time to time during its winter nap. No tach bounce or start so I changed the DME relay. Still no tach bounce but it started. I tried turning on the headlamps but not only did they not activate (or turn on), the engine quit and wouldn't restart. $¥©£√#!
1977 924 Guards Red (parted and sold) 1987 924s Alpine White (sold) 1987 924s Kopenhagen Blue (my Lowencash tribute track car) 1987 924s Garnet Red (with FIAMM air horns!) 1982 928 Silver (sold) |
Essentialist
Took two layers of tint off Targa window while it's off the car. 'Very careful to avoid the defroster wires, but sometimes bits of dark lines came off with the tint anyway, leaving a faint yellow line underneath. Are the wires embedded in the glass or sitting on the surface. How do I test for continuity. If they're shot I'm thinking I should scrape off everything. Is there a way to test this?
Like father, like daughter 74 Targa Outlaw 60 Drauz Roadster Outlaw |
Just had the 968 painted.
Byron ![]() 20+ year PCA member ![]() Many Cool Porsches, Projects& Parts, Vintage BMX bikes too http://www.bvdmotorsports.com Active Rennlist Member. http://members.rennlist.com/racerbvd/ See blog for my For Sale & Wanted List. http://www.914club.com/bbs2/index.php?automodule=blog&blogid=337& |
I bought a used hatch with tint one time, the defroster grid main bus had been cut with a razor when the tint was installed ...
I used carb cleaner to dissolve the tint glue and gently used a plastic scraper to remove most of it without further damaging it. If you are lucky the defroster grid will still work (it is on the surface). individual wires can be repaired using a permatex repair paint. if the bus has been cut, i couldn't tell you... The only way I know to test is in real life bad weather. The grid wires all run in parallel so testing resistance or continuity isn't going to work. Start a new thread and maybe there will be some other ideas... Last edited by djnolan; 01-24-2019 at 11:19 AM.. |
Patrick
Let's see... It's 33 degrees outside, threat of a snowstorm coming, remnants of street salt everywhere; it must TB, BB and water pump replacement time!!
1984 944 NA, constant tinkering |
Edward Larsen
I won a used radio on ebay...
![]() Skickat från min iPhone med Tapatalk
curtisr
Ordered parts to do a valve cover replacement on my 924s. (From Pelican, actually. No affiliation.)
Ordered new plate:
curtisr
Patrick
WP in...!
Antipurist
Installed new MOMO "D" wheel so i can get my fat azz in alot easier.
Makes a world of differance ![]() |
Well I spent the night replacing the starter and cleaning up the cable ends. Earlier in the week I replaced my fuel injectors. Still have a few other things to do before I try starting it up...
![]() ![]() ![]() ![]() Fixed the intermittently flashing fuel low light. The connection for the copper wire in the sender had snapped. Cleaned it up an soldered it back together.
1987 944 Summer 2006 E90 Winter |
Politically Incorrect
924S
Replaced front turn signal bulb. 535i Replaced connector on oil level switch. Replaced oil pressure switch. Oil, Filter & reset light. Adjusted crank position sensor...AGAIN.
Edek '87 924S '91 535i |
Can anyone confirm that this is true? https://thecarplayer.com/blogs/news/apple-carplay-for-my-old-porsche?_pos=1&_sid=913e1e36c&_ss=r
Can you actually get Carplay in an old Porsche? |
Found the problem...
![]() As luck would have it, I just happen to have a spare 90A Bosch alternator for a 1988 BMW E30 M3 [RIP] on my miscellaneous parts shelf (doesn't everybody?). The complete rotor assembly, with bearings and slip ring is identical to a 1987 Porsche 924S 90A Bosch alternator. Swapped over the rotor assembly and voltage regulator and POOF!; I have a rebuilt alternator, and it works perfectly. Oh, and while I was at it, I installed a WAI 24-94250 alternator clutch pulley I also had hanging out on my "to-do" projects shelf. Noticeable improvement in idle smoothness (with and without A/C on). Still feeling out the other benefits.
Oil and filter change, fixed leaky oil pressure sender, replaced power steering hose and finally made an appointment for an alignment.
Thread Tools | |
Rate This Thread | |
