LinkBack Thread Tools Rating: Thread Rating: 6 votes, 3.67 average.
Can you guys guess what I'm doing..
http://www.bvdmotorsports.com
Active Rennlist Member.
http://members.rennlist.com/racerbvd/
See blog for my For Sale & Wanted List.
http://www.914club.com/bbs2/index.php?automodule=blog&blogid=337&
Old 07-24-2013, 05:45 AM
  Pelican Parts Catalog | Tech Articles | Promos & Specials    Reply With Quote #1621 (permalink)
Checking if those struts will hold up the hatch in cold weather?
I had my fuel pump, transmission oil, and engine oil changed. Turns out I have a very small radiator leak. Nice part is that I already have an almost new radiator, in my 944 project car. I'll probably upgrade it for the V8 engine so I can use the one on it right now for my 924S.
Currently have: Guards Red 1987 924S 16v -- Light Blue Metallic 1980 928
Gone: Minerva Blue 1979 928 -- Gray 1985.5 944 -- Black 1989 944 -- Black 1984 944 -- Black 1987 944S -- Alaska Blue 1974 914 1.8 -- Guards Red 1983 944 -- Guards Red 1987 924S -- White 1988 924S -- Maraschino Red 1987 944 Turbo -- Beige 1981 924 -- Red 1984 944
Old 07-24-2013, 06:00 AM
  Pelican Parts Catalog | Tech Articles | Promos & Specials    Reply With Quote #1622 (permalink)
Vey, yes mister President
cockerpunk's Avatar
i reset my fuel pressure, banged it up a few PSI cuase i think im running lean on boost.
last night i was having a hell of time getting it above stock pressure without a small leak at the #2 injector seal, but today she seems to hold just fine. all the way past 40 psi. i wonder if she just needed to warm up to reseat the seals. air in the system pushing the seals open?
Motion for summary judgement, your honour. That's the only rich thing in here. The comedy of it all, not the claimed wealth of contributors. -Lapkritis
Old 07-24-2013, 02:28 PM
  Pelican Parts Catalog | Tech Articles | Promos & Specials    Reply With Quote #1623 (permalink)
GregD's Avatar
Put on a new clutch master cylinder to match the new slave. Then bled the system. put in a new fuel sender last week. Fixed the odo where it wasn't working. Mine turned out to be the pop metal gear was just spinning. Took it apart and scarred the inside the use some loctite quick metal on it an put it back together. So far so good...
Greg DeBord
PCA Member
73 914/6 conversion
83 944 (newest addition)
99 996 aero coupe
Old 07-26-2013, 07:55 PM
  Pelican Parts Catalog | Tech Articles | Promos & Specials    Reply With Quote #1624 (permalink)
Garage Helper
Cocacolakidd's Avatar
Send a message via Yahoo to Cocacolakidd
Installed a new Supercharger to my 85.5 - Installed a Turbo Speedo and Tach. Then plugged a nylon tubing to the back of the turbo psi boost gauge and led it over to the passengers side. So when I want to go fast I have my girlfriend blow on the tubing.........Oops
78-924 traded for 80-931 traded for 84-944 traded for 85.5-944 (7th one now).
UAV-M1 (Urban Assault Vehicle - Model 1)
Bless the lowered, and pass the nitromethane.
Pedal to the metal till you see the gates of hell then brake
NLA - No longer available is a four letter word
Old 07-26-2013, 08:23 PM
  Pelican Parts Catalog | Tech Articles | Promos & Specials    Reply With Quote #1625 (permalink)
GreenWater's Avatar
Pictures.....Of the super charger that is.
www.Only944.com Porsche parts, Only better, Only944
87 944 N/A 165,000 miles
84 944
Saved by God, because I could not.
Old 07-26-2013, 10:44 PM
  Pelican Parts Catalog | Tech Articles | Promos & Specials    Reply With Quote #1626 (permalink)
Volhv's Avatar
Installed GreenWater's short shift linkage. Did not need to jack the car up, remove wheel, or anything. But the gravel in my backyard is quite uncomfortable.
1986 944 NA Sapphire Metallic
http://944porsche.blogspot.ca/
Old 07-26-2013, 11:03 PM
  Pelican Parts Catalog | Tech Articles | Promos & Specials    Reply With Quote #1627 (permalink)
GreenWater's Avatar
Awesome. The short shifter works great and make shifting so much better. Enjoy!
84 944
Old 07-26-2013, 11:15 PM
  Pelican Parts Catalog | Tech Articles | Promos & Specials    Reply With Quote #1628 (permalink)
sushiman007's Avatar
Need a tutorial on the odo removal/fix, please!
Originally Posted by GregD View Post
...Fixed the odo where it wasn't working. Mine turned out to be the pop metal gear was just spinning. Took it apart and scarred the inside the use some loctite quick metal on it an put it back together. So far so good...
I wished someone could post a step-by-step, pictorial, how-to DYI on that, because I have the same problem on my '84...:/
Old 07-27-2013, 04:41 AM
  Pelican Parts Catalog | Tech Articles | Promos & Specials    Reply With Quote #1629 (permalink)
GregD's Avatar
I kind of used a combination of this Pelican Technical Article: Porsche Dashboard Gauge Repair and Refurbishment and this http://www.odometergears.com/howto/Porsche_944_Odometer_Gear_Repair.pdf. The only difference was that the 944 has the plastic gear on the other side. I didn't take it completely apart, just far enough to slide the rod out of the odo dials to get the pop metal gear off. Then I just used a small micro screwdriver to basically scratch the inside of the gear. It is pressed on, so you have to deform it to make it hold. My loctite quick metal was unopened, but old so I'm not sure it helped or not, but it sounded like a good idea. Making pressed on gears tighter was what it is designed for. I did replace the plastic gear while I was there also. I should have taken some pictures, but didn't.
To get the gauge out on an early car, I popped the Multi gauge on the the left, only 1 multi wire connector on the back. You can get to the speedo cable easier from this side. Also popped the tach because the mpg gauge on the tach is connected to the speedo. I didn't take the steering wheel off, but I did loosen the 2 screws for the gauge trim.
Greg DeBord
PCA Member
73 914/6 conversion
99 996 aero coupe
Old 07-27-2013, 05:35 AM
  Pelican Parts Catalog | Tech Articles | Promos & Specials    Reply With Quote #1630 (permalink)
Thank you, GregD! That sounds like a weekend project for me
Not this weekend, though; too hot and humid here in SE Texas (and I don't have an air-conditioned garage).
Actually, the first on my to-do list should be this annoying little big problem:/
Old 07-27-2013, 12:09 PM
  Pelican Parts Catalog | Tech Articles | Promos & Specials    Reply With Quote #1631 (permalink)
Painted the bottom of the race car with por 15
Old 07-27-2013, 09:14 PM
  Pelican Parts Catalog | Tech Articles | Promos & Specials    Reply With Quote #1632 (permalink)
I took a female friend for a drive out in the hills where I live to a little brewery with fantastic beer.
She loves my car. This is a good sign.
Old 07-27-2013, 09:21 PM
  Pelican Parts Catalog | Tech Articles | Promos & Specials    Reply With Quote #1633 (permalink)
GreenWater's Avatar
If a girl loves a 944 then she is a keeper!
84 944
Old 07-27-2013, 09:43 PM
  Pelican Parts Catalog | Tech Articles | Promos & Specials    Reply With Quote #1634 (permalink)
924S, but yeah. She's also interested in my 944 LS1 project. She loves driving fast...just yesterday she told me she went over 160 in a V12 Mercedes. O.o
Apparently one of her cousins is rich and spent over half a million dollars on a custom 911 when he was in Germany. And my friend herself just put money down on a brand new Subaru BRZ.
Very interesting family she has...apparently her mother was in the record business and knew a lot of really famous singers...
Funny the connections random people have.
Old 07-27-2013, 09:49 PM
  Pelican Parts Catalog | Tech Articles | Promos & Specials    Reply With Quote #1635 (permalink)
mhariush's Avatar
worked on my vacuum lines and tried my new shop pads
Current: 87 944S Black/Black, 89 944 Turbo S ANDIAL White/Burgundy, 78 924 Black/Black, 2006 Cayenne, 80 924 Turbo, 69 Beetle
instagram @mhariush @technikercompany
http://stores.ebay.com/Techniker-Parts/
Old 07-27-2013, 11:24 PM
  Pelican Parts Catalog | Tech Articles | Promos & Specials    Reply With Quote #1636 (permalink)
^ I like that pic. Car looks expectant. Bucolic setting.
We did the top end and found the 87 motor is worth saving. Today we tune the 924.
Old 07-28-2013, 07:32 AM
  Pelican Parts Catalog | Tech Articles | Promos & Specials    Reply With Quote #1637 (permalink)
I like that Porsche fender/hood protector thingie!
How much, mhariush; and where did you get it?
Originally Posted by mhariush View Post
Old 07-28-2013, 07:52 AM
  Pelican Parts Catalog | Tech Articles | Promos & Specials    Reply With Quote #1638 (permalink)
alan6272's Avatar
Took the wife for 1.5 hour ride around the back roads will upload video on you tube later. Car was superb
1983 944 ,1983 V-65 magna
catalina22 sold
baja ski boat sold
my toys
Old 07-28-2013, 09:10 AM
  Pelican Parts Catalog | Tech Articles | Promos & Specials    Reply With Quote #1639 (permalink)
I had some stumbly issues on my 86 951. replaced all of the vacuum lines and WOW!
Spools up like new and FAST!!!!!!Daily driver for over 7 years! Who says these cars aren't
dependable?
Old 07-28-2013, 09:39 AM
  Pelican Parts Catalog | Tech Articles | Promos & Specials    Reply With Quote #1640 (permalink)
