-   -   Best timing replacement instruction? (http://forums.pelicanparts.com/porsche-924-944-968-technical-forum/667819-best-timing-replacement-instruction.html)
konig10 03-25-2012 07:15 PM
Hi! I'm getting ready to replace timing and water pump on 86 944 na, what is the best website that someone could recommend for instruction on doing that, Can someone also let me know the info on the updated water pump with belt guard, final question, I don't want to spend 650.00 on a Porsche brand belt tensioner tool can someone refer me to a affordable one that does the same thing thanks, I have the haynes manual and I know it doesn't have all the updated info
alan6272 03-25-2012 07:22 PM
Take a look at "Clark's garage.com" the details are in there, I do my tension timing belts by feel, but been doing them forever. Also look into youtube some good videos on there for this.
ernie9944 03-25-2012 07:40 PM
Clark's Garage Home Page once on the site enter -Garage Shop Manual-click on letter- T- scroll down to-Timing Belts.:D
marbleusmike 03-25-2012 08:57 PM
I bought a very accurate gauge/ tool kit at ArnnWorks Specialty tools. Google it.
About $150. to 195.ish with a case.
mikepellegrini 03-25-2012 09:17 PM
The very best thread on belt tensioning: http://clarks-garage.com/phpBB2/viewtopic.php?t=1935&highlight=twist
Cocacolakidd 03-25-2012 10:51 PM
Also see: Timing Belt Change Porsche 944 - Video #1.wmv
Check in on u-tube - the water pump and belt change is in series #1 thru #8.
Enter: "Timing Belt Change Porsche 944 - Video #1.wmv", in the top search bar, then follow thru with the next series, #2.wmv, #3.wmv, etc.
A good follow up to the other sites -
John_AZ 03-26-2012 05:47 AM
+1 for a belt novice that fears the dreaded outcome of a bad install---
Bent valves in the head
944 Timing Belt Tensioning
Double check your work with the "WP water pump pulley test"
http://forums.pelicanparts.com/uploa...1332765762.jpg
Van on Rennlist has done a couple DIYs on belts and waterpumps-very skilled.
Here is his conclusion:
http://forums.pelicanparts.com/uploa...1332765976.jpg
GL
John
John_AZ 03-26-2012 05:52 AM
Oh,
If you reply, I am sure someone will tell you about the updated water pump, block off plate, 46 mm idler roller. Or you could just look on Pelican Parts:
Porsche 924S/944/968 Water Pumps & Hoses - Page 1
John
konig10 03-26-2012 11:58 AM
Thanks for the info everyone read through the clarks garage, that will definitly help, it seems like all the major parts suppliers offer updated water pumps or later style waterpump obviously I need the updated
rickharrison 03-28-2012 03:15 PM
If you choose rebuilt, call Zims...2 yr warranty.
mytrplseven 03-28-2012 04:42 PM
Cocacola kid has it righ IMHO. I used the procedure in the videos and couldn't be more satisfied. It makes it easy and sensible. Guages?? We don't need no stinking guages!! :)
