A.J.
tychain99's Avatar
4 lug to 5 lug conversion
what do i need to convert the 4 lug 924, to 5x130 bolt pattern. Some guy on a VW forum was talking about buying adapter/spacers which would make the changed,. seemed expensive. Also it seems like it would take away strength. I can get the parts from a 944, or later 924, but what do i actually need to have so i can look for the parts separate as opposed to buying a separate donor car.. thanks..
1980 auto- cashmere beige
1984 auto- black on black
Old 04-25-2012, 07:28 PM
ideola's Avatar
I have everything you need, boxed up and ready to go:
Ideola's Garage: Used Suspension Swag for Transaxle Porsches
15 981 GTS | 88 924S SE | 82 931 Holbert | 82 931 Rallye | 81 937 | 81 Euro 931 | 81 Weissach | 80 US 928 | 80 US 931 '941' | 80 US 931 | 80 931 GTR | 79 Sebring | 78 D-Prod Replica | 78 w/D-Prod kit | 78 Poli-Form | 78 Limited Edition | 77 Martini
Old 04-26-2012, 01:05 PM
dkbautosports.com
962porsche's Avatar
i'm junking 2 of my early 944's . so if you need any thing send me a PM .
Old 04-26-2012, 01:44 PM
I think the cheapest solution is to buy drums and rotors that are drilled for 5 bolt.
If I'm not mistaken, the 4bolt 924 uses the sme drums and rotors as a Beetle.
I used these parts on my '69 Beetle
C13-22-2963-B - FRONT BRAKE DISC ROTOR - 5 X 130MM PORSCHE 911 BOLT PATTERN - FIT ALL W/DISC BRAKES BEETLE/GHIA 47-79 / TYPE-3 66-2/71
C23-501-310 - 5 X 130mm BOLT PATTERN REAR BRAKE DRUM BEETLE / GHIA 68-79 (OVERSIZED)
Old 04-26-2012, 05:10 PM
FrenchToast's Avatar
I would advise against the adapters. They create a large cantilever the hubs likely aren't designed for.
Given jrbennett's advice, looks like you have to decide if you want all discs or not.
Take Care!
Old 04-26-2012, 05:24 PM
Toofah King Bad
Rasta Monsta's Avatar
Ugh, that Ebay crap is. . .umm. . .crap.
Ideola's setup is cheap for what you get, and is the right way to do it. No brainer really. . .
» 1987 924S Turbo - Got Boost? «
"DETERMINATION. Sometimes cars test us to make sure we're worthy. Fix it." - alfadoc
Old 04-26-2012, 07:14 PM
