Banned
944.537.081.02 is this drivers side or passenger side door handle?
found a non script exterior handle for 944 and dont remember if its a drivers side or passenger. it looks like an 'L' is in front of part number but not positive as eye are old and dont work. anyone know the difference?
Old 03-30-2012, 10:58 AM
Garage Helper
Cocacolakidd's Avatar
Send a message via Yahoo to Cocacolakidd
A good way to tell is with the linkage. The linkage should be facing down with the handle in a horizontal position. With the linkage and handle in this position the key cylinder will be on the left for passengers, and on the right for drivers. If the linkage is in the correct position it will hang better and be slightly longer than upside-down.
It seems that the number you have there is a casting number as the correct part numbers are as follows.
944 538 905 00 is left side 85.5 and up
944 538 906 00 is right side 85.5 and up.
477 837 037 H is left side for early
477 837 038 H is Right side for early
78-924 traded for 80-931 traded for 84-944 traded for 85.5-944 (7th one now).
UAV-M1 (Urban Assault Vehicle - Model 1)
Bless the lowered, and pass the nitromethane.
Pedal to the metal till you see the gates of hell then brake
NLA - No longer available is a four letter word
Old 03-30-2012, 12:49 PM
seafeye's Avatar
If the part number is ends in an odd number. Excluding the last two numbers the part is for the left side. And yep. Even for right.
Old 03-30-2012, 05:14 PM
968 GUY's Avatar
If you go to the Pelican parts site and plug in any part #, you can find out what part it is.
87 951 all stock exc. cup II's /94 968 6-spd, lowered,17in. RUF Speedlines, M030 anti- sways/ 94 968 Tip, Cup II's, otherwise stock
Old 03-30-2012, 05:25 PM
Garage Helper
Seafeye does that rule of thumb also go for casting numbers ??
Old 03-30-2012, 06:04 PM
seafeye's Avatar
Should work for all. Except if the part is identical to both sides. I believe this is a German DIN standard
Old 03-30-2012, 06:53 PM
