Changing oil filler seals
I recently replaced my intake boot and noticed some sludge on the inside of the boot. I've done some research and all things point to the two seals on the top and bottom of AOS/Oil filler bottle. I bought the seals and plan on replacing them as soon as I get them. Will I need to drain the oil before resealing the oil filler?
Old 04-13-2013, 07:43 PM
AFM #725
Gawernator's Avatar
Nope. Just pop it off. Replace seals and reinstall
Old 04-13-2013, 07:53 PM
Awesome! Thanks for your help!
Old 04-13-2013, 08:04 PM
1983 944 N/A
POPS 83 944's Avatar
You will need to remove your intake to get to the bolts, so order intake gaskets also, and if the vacuum lines are old, might as well get those also.
"To my family, the 944 is more than a new car. It is a new and true Porsche.
At Porsche, excellence is expected."
Dr. F. Porsche Stuttgart
Old 04-13-2013, 09:00 PM
AFM #725
Gawernator's Avatar
Big list of "while you're in there" items, namely the rear and front ICV hoses, vacuum lines, AOS breather hose, dipstick O-ring
Watchdog Armory Racing AFM #725 Thanks to my 2017 Sponsors: JPH Suspension | AXO | Armour Bodies | BELL Helmets | Braven | EVLUTION Nutrition | Forcefield Armor | FunTrackDayz | Galfer | Motion Pro | MOTUL | Matrix Racing Concepts | ODI Grips | OGIO | Shorai Inc. | SPEEDMOB | Vortex | Woodcraft | Wicked Audio
http://www.gawerracing.com
Old 04-14-2013, 01:05 AM
9FF 9FF is offline
9FF's Avatar
After you've cleaned out all the sludge from the intake and while its off is also a good time to clean and reseal your throttle. Throttle reseal kits are cheap and it takes about an hour to do.
Old 04-14-2013, 04:29 AM
You may want to have a couple of the ICV rubberized mount bolts on hand also, they are known to perish from the engine heat.
Old 04-14-2013, 05:15 AM
Patrick
pfarah's Avatar
So much for just replacing the oil seals.
1984 944 NA, constant tinkering
1983 "Beastie" - Safari Build
Old 04-14-2013, 09:25 AM
AFM #725
Gawernator's Avatar
It took me more like three hours to reseal the TB but 9FF is correct! Lol
Old 04-14-2013, 09:41 AM
