ongoing for about 2 months
At idle I get a little popping through the exhaust but revs just fine. when driving I have to feather the clutch the gas to move. at speed and in any gear, if i put my foot on the gas and press more than1/4 inch it boggs down the power but wont stall out. if i just accelerate SUPER SLOWLY everything is fine.(not good for merging onto the interstate)
I checked the AFM and TPS , in and out of the car and got good readings. One contact on the potentiometer was raised a little higher, but i bent it back down and aligned to a fresh surface. Plugs and wires look ok. Voltage through injector wiring is spot on. Unplugged each connection to the injectors at idle and each, as should, dropped off and then picked back up again once reconnected. Replaced fuel filter last month and patched all leaks that were in the gas tank. Engine reacts just the same if not slightly better with O2 sensor unplugged in as plugged. Temp sensor tested good as well. Tomorrow i'm pulling the fuel rail and reverse flushing the injectors to clean them out and testing fuel pressure. I do have a small oil leak (maybe 5 drops a day sitting cold and at idle 5 per minute, due to a gasket leak) Whats next to check before I have to give up and take it to the shop? O2 sensor, DME remapping..........
Black 1984 944 2003 Land Rover Freelander SE3 |
also, on this post
Injector Cleaning the 9v transistor battery he speaks of, is that some special battery or will any regular 9v battery work?
1988 944 2.5L 8-v NA 301k
My guess: 944.602.115.00
'88 8v n/a 301k with 41k on current TBelt M454 M533 M650 M425 M418 ![]() New Feb'13 Bridgestone Grid 019.. awesome. Paid just $1,700 running & inspected. Big RUSH Fan! Lic Plate = LIFESON |
TPS tests fine. At idle its ay 900rpm and rough. Disconnected TPS, its at 1200rpm and smooth. Still lack of power and smoke testing in the morning eventhough I don't hear any leaks.
Ignition coil is good as well
Black 1984 944 2003 Land Rover Freelander SE3 Last edited by Ederd; 03-30-2012 at 01:39 AM.. |
Location: In a dumpster behind Albertson's in Los Angeles County
1989 944 NA Glacier Blue - SOLD IT 1989 944 S2 Alpine White T-Boned (totaled) by a lady dressed in a CLOWN costume (RIP ) Apr 89 - Mar 081988 944 Turbo S Silver Rose Metallic, K27/6, Vitesse MAF, Tial 38mm DP WG Semper Fi |
Garage Helper
Could it possibly be that your Cat is clogged ? Disconnect at the first bolted joint ahead of the Cat and test it that way.
78-924 traded for 80-931 traded for 84-944 traded for 85.5-944 (7th one now). ![]() UAV-M1 (Urban Assault Vehicle - Model 1) Bless the lowered, and pass the nitromethane. Pedal to the metal till you see the gates of hell then brake NLA - No longer available is a four letter word |
cat is gone. i have a straight pipe.
If it was any regular hot rod Id say the cam had a bad lobe on it
944 addict
Have you pulled the afm external connector to see that it's good contacts? My car ran like that when I forgot to plug it back in (duh!). Another thing is to check the soldered conections in the DME. If you can find a loaner, that will eliminate that to start with. Have you done a thorough vacuum system check? Vacuum leaks alone can cause a lot of weird symptoms. there's several ways to do it. Mine is 7 to 10 psi air into the intake j boot (2" PVC cap with air hose fitting threaded into it, air applied, spray soapy water solution on everything and watch for bubbles. I even found one on the throttle body (bad shaft seals).
3 944's, 2 Boxsters and one Caman S, and now one 951 turbo. Really miss the Cayman. Some people try to turn back their "odometers." Not me. I want people to know 'why' I look this way. I've traveled a long way and some of the roads weren't paved. |
for what it's worth, you may be firing on three or not timed. i would try new plugs( keep in mind a plug can spark and still be bad) ,and recheck your timing.
Toofah King Bad
Vacuum leak?
» 1987 924S Turbo - Got Boost? « "DETERMINATION. Sometimes cars test us to make sure we're worthy. Fix it." - alfadoc |
check the coolant temp sensors...i had the same symptoms, car would basically shut off (but still be running, just no power) if i went to mid or full throttle suddenly. changed the sensor out - problem fixed
i have literally 10 of each of the 2 sensors if you need some. all used, but usable. |
