pig tail
I have a pig tail at the back of my engine I believe its the speed reference sensor. It is a round 3 prong male piece, but I can not find were it plugs in to. I would put up a picture but computer wont connect to my phone. by the way vehicle is an 87 944S.
Old 04-07-2012, 07:27 PM
In the Fires of Hell.....
kdjones2000's Avatar
Sounds like your O2 sensor.
PCA Instructor: '88 951S - with LBE, Guru chips, 3Bar FPR, 1.3mm shimmed WG, 3120 lbs, 256 RWHP, 15 psig boost
Old 04-07-2012, 07:35 PM
its not the o2 has two males and one female.
Old 04-07-2012, 08:05 PM
Old 04-07-2012, 08:10 PM
alright found out it is the top dead center sensor which is only used by mechanics, so it is otherwise useless. Now my question is had top end rebuilt put it back together and have no fire every thing is hooked up and some times it back fires.
Old 04-07-2012, 08:52 PM
944 addict
mytrplseven's Avatar
Send a message via AIM to mytrplseven
See if you have the reference sensors switched. Check to make sure your AFM is plugged in. Is your firing order on the distributor correct? If it backfires, you do have spark, just not at the right time.
3 944's, 2 Boxsters and one Caman S, and now one 951 turbo. Really miss the Cayman.
Some people try to turn back their "odometers." Not me. I want people to know 'why' I look this way. I've traveled a long way and some of the roads weren't paved.
Old 04-08-2012, 06:50 AM
thanks it was my firing order 1 and 3 were backwards got it started after 7 months.
Old 04-08-2012, 10:46 AM
