-   -   1988 in 97 (http://forums.pelicanparts.com/porsche-924-944-968-technical-forum/670793-1988-97-a.html)
conor23 04-10-2012 09:53 AM
1988 in 97
could you put a 1988 944 engine in a 87 944?
murrayg 04-10-2012 10:01 AM
If you had a 97 944, likely.
nynor 04-10-2012 10:32 AM
perhaps you meant an '87 944.... if so, yes, you can.
conor23 04-10-2012 12:31 PM
yeah I did thanks
John_AZ 04-10-2012 01:21 PM
Get the '88 DME if you get the '88 engine.
John
nynor 04-10-2012 01:54 PM
John
i thought they would be the same, more or less. what is the difference?
John_AZ 04-10-2012 06:10 PM
The '88 went from 150HP to 160 HP.
Part numbers are different. '85.5 to '87 should be able to use the same DME. The later DMEs to '87 have a few modifications/upgrades but should work.
This is a discussion on the chips and "maps"
http://forums.pelicanparts.com/porsche-924-944-968-technical-forum/544412-tried-multiple-chips-best-88-924s.html
John
nynor 04-10-2012 06:22 PM
gotcha.
Copyright 2020 Pelican Parts, LLC - Posts may be archived for display on the Pelican Parts Website
