HELP!!! oil on spark plug
I pulled out my spark plugs and found oil all over the spark plug closest to the firewall. The spark plug was black and oil was baked on it.
What kinda a damage and cost am I looking at?
Old 04-26-2002, 05:19 PM
the other 3 spark plugs were fine
Old 04-26-2002, 05:40 PM
todwic's Avatar
Send a message via AIM to todwic Send a message via Yahoo to todwic
more 411 plz
Does it knock? Is it a daily driver, has it sat for a while? Ingition problems?
Do a compression test.
Buy a Hanes manual so you'll have something to cuss and kick around your garage.
Did you overfill the oil? Any oil in your water? any water in your exhaust? Does my bunghole have to talk so much?
Old 04-26-2002, 06:12 PM
1987 944 na
it does not knock, yes it is a daily driver
I have a new cap and rotor and I am waiting my ignition wires from jacobs
I did not over fill the oil but, no water in the oil.
Could it be 1 bad piston or piston rings???
Old 04-26-2002, 06:48 PM
PorscheG96's Avatar
Send a message via AIM to PorscheG96
Which end of the spark plug is the oil on? If it was on the end that fires [inside the combustion chamber] then it would've burned off and that's weird. If it's on the end where the plug wire connects then your cam gasket is leaking, no big deal really.
Old 04-26-2002, 08:13 PM
the end of the plug where it sparks is all black and i belive it is oil that has hardened on it. it almosted bridged the gap.
Old 04-26-2002, 09:20 PM
Are you having to add oil to the engine?
Try switching two plugs around and see if the problem follows the plug. If it does, your fix would cost about $2.
Old 04-27-2002, 03:53 AM
yes i am adding oil to the car
i tried a new spark plug and sam thing happened to it
Old 04-27-2002, 09:23 AM
I am using 10w30 regular oil should I use something thicker?
Old 04-29-2002, 06:09 AM
Nowhere do I read that you tested for spark at that plug. Remove it from the head and ground the body of the plug. Turn over the engine and prove that it is sparking. This will tell if it is an electrical problem.
That being said, the #4 cylinder is furthest from the cooling of the radiator and can be the first to have problems because it runs hotter.
Good luck,
Jon Aborn
Old 04-30-2002, 04:00 PM
justin's Avatar
Cjoven,yes thicker oil will help,if it is burning oil try running 20w-50 or 10w-40 depends on your climate,if it gets really cold there run 10-40 if not then go with 20-50.
Good luck
Texas hosts the 928 Owner’s Club OCIC in 2009
www.928ocicdfw09.com
1980 928 5 speed and a few mods..........
928 OC member
PCA member
Old 05-01-2002, 12:24 AM
ok thicker oil goes in this weekend,
i checked to see if it was getting spark and yes it is
could old ignition wires, rotor and cap cause that to happen?
Old 05-01-2002, 05:09 AM
