James Chimney
Injector Cleaning?
what (if any thing) are you guys using to as an additive to your gas for fuel injector cleaning? And how often?
Old 04-26-2012, 02:34 AM
9FF 9FF is offline
9FF's Avatar
Nothing, just use good gas like Chevron Techron or Texaco and send your injectors in to Witchunter for a deep clean every few years.
Old 04-26-2012, 06:16 AM
944 addict
mytrplseven's Avatar
Send a message via AIM to mytrplseven
If you suspect that you have an injector issue, buy a cheap noid light to verify the impulses are getting to the injectors. 9FF hits the nail on the head: Premium gas, Make sure your filter and fuel strainer are taken care of and Witchunter for rebuilds. It cost $100 round trip to rebuild your injectors and only a week down time.
3 944's, 2 Boxsters and one Caman S, and now one 951 turbo. Really miss the Cayman.
Some people try to turn back their "odometers." Not me. I want people to know 'why' I look this way. I've traveled a long way and some of the roads weren't paved.
Old 04-26-2012, 06:52 AM
My 84 944 sat for about 7 years before I bought it. It was ran monthly so it was sorta okay, but you could tell it wasn't 100%. I ran a bottle of techron and my gas milage increased noticably and the engine was smoother and ran better.
YMMV
Old 04-26-2012, 07:34 AM
Proprietoristicly Refined
John_AZ's Avatar
Most fuel injetor cleaners and fuel injector service at shops will take more out of your pocket instead of removing varnish on the injectors.
If you do not want to send them to WitchHunter Performance - Injector Cleaning & Flow Testing Services for testing, go to WalMart and get a can of SeaFoam. Follow directions.
Sea Foam | How to Use Sea Foam Motor Treatment
If you feel no improvement, see Witchhunter.
Other uses as well for engines that sat 7 years. Gummy lifters (cam followers) +++.
John
1988 924S, 85,750K ..+ 1987 924S, 154K DD (+15K est. bad odo)
Old 04-26-2012, 08:31 AM
RedBaron's Avatar
I sent mine to witch-hunter when I pulled my engine. They did a good job and put new seals on the injectors. I use LiquiMoly/LubroMoly products on my Audi, such as the Jectron and Ventil cleaners. Both are very good products. LiquiMoly is the equivalent of Mobil 1 in Germany and they have a very good reputation.
LIQUI MOLY - Motor Oils, Additives, Car Care - Products - Ventil Sauber
LIQUI MOLY - Motor Oils, Additives, Car Care - Products - Jectron
I believe Napa and Pelican carry it. If not there is a BMW place in NH that can ship it down to you. I've used Techron before and I have had no issues with it. You are supposed to change the oil after you run the stuff in your tank.
Old 04-26-2012, 08:51 AM
"Dude! You kicked my car.
Rudeboy42's Avatar
+1 on Witchunter I used them on my first 944 and it was a great improvement since the car had been sitting for 2 years before I got it. I may have an extra set of injectors for you if you don't want your car to be down for that long.
Old 04-26-2012, 08:10 PM
James Chimney
how hard to replace them Adam? I my take you up on that
Old 04-27-2012, 01:53 AM
The problem with fuel systems cleaners you add to the gas is they loosen crud in the tank, filter and lines and deposit them further downstream like in the injector micro screens. Then you will really need to see witchhunter to get these clean. Also need to see witchhunter to replace the injector spray nozzles.
Old 04-27-2012, 03:27 AM
Carmagic.us
rothaus's Avatar
Did Anybody had the injectors services with Injector Experts
I found the link on the Racing Junk site.
For BA7s Dash LED, and External Marker LED go to carmagic.us - Now Luftgekühlt Emblems
Old 04-28-2012, 04:31 AM
