Yan Yan is offline
Tie rod assembly vs tie rod end?
Hi!
Today, I went for an alignement and the mechanic told me that the passenger's inner tie rod was worn and needed to be changed before any alignement. I own a 944 Turbo. I live in Canada and I can't find any provider that'll sell only the inner tie rod instead of the whole assembly so it would cost me as high as 175$ canadian (about 105$ US). How can I establish which specific part need to be changed (the whole assembly or only the tie rod end)? It would cost me much less money.
Thanks alot!
Yan
Old 05-02-2002, 04:31 PM
Post
what are tie rods?what do they do?
Old 05-02-2002, 05:41 PM
robs944's Avatar
Yan,
If you need just the Tie Rod there are many sites that sell them http://www.thepartsbin.com/ and http://**********.com they also sell the tie rod ends
Check the Tie Rod ends to see if the rubber is cracked or torn, if so then they should be replaced. I am not sure about checking the Tie Rod itself, the only reason I replaced my was because one was bent. You can pull back the boot on the Steering Rack and check to see if there is a visual damage??
Hope this helps......
Rob
Rob
87 944 * 89 951
"When I die, I want to go peacefully like my Grandfather did, in his sleep -- not screaming, like the passengers in his car."
Old 05-03-2002, 05:14 AM
