Send a message via AIM to Icey1174
3rd Gear Grind
My 17 year-old son has been driving the 944. While he is not a perfect stick shift driver he is decent. Today he told me the car grinds a little when going into 3rd gear.
I recently replaced the master and slave cylinders for the clutch about two months ago and have had no problems at all. The clutch itself is about 5 years old and has been problem free.
I drove the car all day yesterday. He drove it some last night and about 10 miles today. I took it for a ride today and everything shifts great but 3rd gear. It grinds some when going into 3rd almost like the clutch is not fully engaged. It does go into 3rd with a little push.
Any ideas on the problem? It does smell like something, maybe the clutch, was burning. I would suspect a problem in 1st or 2nd gear if it is a clutch problem, not 3rd. 1st and 2nd shift great with no jerking at all.
Thanks in advance for any help!
John
'87 944 N/A (first Porsche)
'95 E-350 Diesel
'03 S-Type Jag 3.0
'03 Taurus SES
'06 Eddie Bauer Explorer
RIP SoCal
Old 04-18-2012, 03:49 PM
I checked Clark's and all it really talks about is the rubber disk clutch, which the new one is not, and measuring the clutch disk for wear.
I measured the clutch disk and the gap measures to be 26mm. Clark's says a new disk should measure 18mm and that you should replace at 34mm. I am dead in the middle of those numbers so I think I may be safe there.
Could it be some minor burning of the clutch that will be ok once it full cools down? I took it for another quick ride down the road, about a 1/4 of a mile. I tried just skipping thrid and going to fourth. That seems to work ok.
Any ideas???
John
'95 E-350 Diesel
'03 S-Type Jag 3.0
'03 Taurus SES
RIP SoCal
Old 04-18-2012, 04:29 PM
Sounds like your 3rd gear syncro is starting to go bad. You might want to change out your transaxle gear oil if you haven't already done so. I don't know if a synthetic gear oil would be better than a mineral oil for this problem. Synthetic is slippery and might help the problem or might make it worse. You might want to do some research on the matter.
Old 04-18-2012, 04:35 PM
Reverse used to have this problem. It almost seems like the problem has moved from reverse to third. I changed the gear oil about two years ago. Any recommendations? Purple Magic?
John
'95 E-350 Diesel
'03 S-Type Jag 3.0
'03 Taurus SES
RIP SoCal
Old 04-18-2012, 06:09 PM
AFM #725
Gawernator's Avatar
Redline MT-90 75-90W GL-4
Watchdog Armory Racing AFM #725 Thanks to my 2017 Sponsors: JPH Suspension | AXO | Armour Bodies | BELL Helmets | Braven | EVLUTION Nutrition | Forcefield Armor | FunTrackDayz | Galfer | Motion Pro | MOTUL | Matrix Racing Concepts | ODI Grips | OGIO | Shorai Inc. | SPEEDMOB | Vortex | Woodcraft | Wicked Audio
http://www.gawerracing.com
Old 04-18-2012, 06:17 PM
