hi ,, my clutch has the right amount of freeplay ,but the pedal, it seems to sitck right at the point where the clutch becomes fully engaged,,, i have to knock it up with my foot.. it doesn't happen all the time, mostly so when i floor it and shift fast, like to get on the freeway fast.... this isn't a porsche speed shifting goody built in to help with that heel toe speed shifting thing???
anyone?? cruzin with the windows down in ventura |
Look around where the clutch master cylinder is,see if you see fluid leaking onto your carpet inside and look under the carpet as well,also if no fluid is present it will most likely be your clutch slave cylinder,but I would replace both and bleed the system. When you replace one the other is usally soon to follow.
Good luck.
Texas hosts the 928 Owner’s Club OCIC in 2009 www.928ocicdfw09.com 1980 928 5 speed and a few mods.......... ![]() 928 OC member PCA member |
It's probably your clutch master cylinder it's easy to replace make sure you replace the slave cylinder while you at it because it will die on you soon if you don't.
