-   -   Can I Use This Thermo Switch??? (http://forums.pelicanparts.com/porsche-924-944-968-technical-forum/673869-can-i-use-thermo-switch.html)
curtisr 04-24-2012 07:01 PM
I ordered a thermo switch for my '87 924s and what came was a three tabbed/pronged (?) switch rather than the two tabbed/pronged model I expected.
To return it would be a considerable hassle as it involves sending it from Canada to the US. So, my question is: can I use it?
Beck/Arnley 201-1266 Engine Cooling Fan Switch
http://forums.pelicanparts.com/uploa...1335319216.jpg
ernie9944 04-24-2012 07:30 PM
[QUOTE=curtisr;6709455]I ordered a thermo switch for my '87 924s and what came was a three tabbed/pronged (?) switch rather than the two tabbed/pronged model I expected.
That thermo switch is for late 944/S/S2/951/968 not 100% sure but I think you will need the 2 pronges same as the early 944 on your 924S.Try to get one from those guy Auto Parts, Auto Part - Buy Auto Parts Online since they are here in Canada.Once on site look under (lightning,body & electrical) parts # 36520.GLhttp://forums.pelicanparts.com/suppo.../coffeecup.gif
ernie9944 04-24-2012 07:45 PM
:oOOP!! part # is OEA 1635975
mikepellegrini 04-24-2012 08:34 PM
The two prong and three prong aren't interchangable.
Plus you need to pair the thermofan switch to your thermostat - so they're in the same temperature range. I forget what the formula is.
If you have the wrong thermofan switch and an 80C (stock) thermostat, the fan may never shut off.
Maybe John AZ or someone will chime in with the correct pairing information?
curtisr 04-25-2012 04:11 AM
Thank you! Will order today. :)
curtisr 04-25-2012 04:13 AM
I did NOT know that! Thank you!
9FF 04-25-2012 05:39 AM
Low temp thermostat 71deg matches 75deg fan switch.
OEM temp thermostat 80deg matches 85deg fan switch.
High temp thermostat 87deg matches 92deg fan switch.
mhr 04-25-2012 07:29 AM
Hey Curtisr thought you may be interested in this. You are close to Kingston right?
I went last year it was fun. If the forecast is good I will go again this year.
http://forums.rennlist.com/rennforums/showthread.php?t=691952&referrerid=76285
curtisr 04-25-2012 05:56 PM
2012 Kingston, Ontario 944 meet - Rennlist Discussion Forums
Yes, we're 10 minutes north of Kingston. I indicated a desire to join in; however, not having my 924 up and running I asked if I could make an appearance in the other Porsche I have. As well, I left a query as to whether it's for petrol-heads or couples, or what...
curtisr 04-25-2012 05:57 PM
Thanks, I will save this for future reference.
smokin_944 04-26-2012 06:48 AM
Wahler thermal fan switches have numbers.
823.959.481 is 75/70*
823.959.481 D is 82/77*
823.959.481 F is 92/87* and
823.959.481 E is 65/60*. Honestly there isn't much of a use for the 65/60* as the fans run a long time. Just my .02 cents.
mhr 04-26-2012 01:31 PM
oh didn't realize was same person. So I look forward to seeing you. Bring whatever and whoever you want. There was a 928 last year and someone also came with da wife.
