-   -   ScottR or rwsams,i need a little bit more help (http://forums.pelicanparts.com/porsche-924-944-968-technical-forum/67387-scottr-rwsams-i-need-little-bit-more-help.html)
JH924S 05-02-2002 03:15 PM
rwsams your right i am replacing my clutch ,now i dont have the sockets needed to get the cv bolts off and the allen head tool for the coupler bolts in the tranny, can i get them at a reg. auto store or what?whats the name for the cv socket? Thanks alot as this is halting the whole job, which so far has been easier than it sounded exspecially for me at 17 on my own.
thanks a lot
Scott R 05-02-2002 06:57 PM
Those are called "cheese head" bolts they require a 12 point tool. You will need two. CV's are an 8mm cheese head tool and the flywheel is a 10mm. These are sometimes called "triple square" tools. You will probably not find these at the local parts store, try your local Snap-On guy.
JH924S 05-03-2002 06:55 PM
sweet thanks
