Order Online or Call:
888-280-7799
McAfee SECURE sites help keep you safe from identity theft, credit card fraud, spyware, spam, viruses and online scams
Porsche | BMW | Mercedes | Audi | Volkswagen | Saab | Volvo | Mini
  Search Pelican Parts:
View Cart | Project List | Order Status |  Help
mhariush's Avatar
AC blows Fuse 1987 944S
Hi,
I have an 87 S that has AC problems. I installed a new AC compressor and the AC was working for a couple of days, though it didn't get ice cold, just cooler. But now fuse #29 blows when the AC button is activated. I have tried three different AC relays, two old (white) and one new Black Bosch that I got from my mechanic.
I have three different AC Control Units and they all do the same thing, or lead to the fuse blowing when the button is activated. I tried the units on my 87 NA and they don't blow the fuse on that one, but that one has an empty AC compressor so I can't test how well they work for cooling.
Anyone have any thoughts what the issue can be? What I should look for and test?
I see some other people has had very similar issues but none of them replied with an answer.
Appreciate it.
thanks!
87 944S Black on Black - Saved from timing belt failure and restoring.
87 944S Burgundy - Parts car being parted out.
87 944 NA Grey and Linen - Sold
Old 04-25-2012, 06:15 PM
  Recommend this thread for the PelicanWiki    Reply With Quote #1 (permalink)
kuehl's Avatar
Unplug the AC compressor clutch coil. Check resistance between wire and compressor body.
Should be 3.0 to 3.5 ohms nominal. If you have a short or an open chances you have a fried coil, in which case you'll need to replace the compressor, drier, flush the system, inspect the compressor to condenser hose, evac, charge and test.
Old 04-26-2012, 04:19 AM
  Recommend this thread for the PelicanWiki    Reply With Quote #2 (permalink)
mhariush's Avatar
Thanks, I'll test the wire. This is a new refurbished compressor that I just installed though. Been reading a bit about this and it seems a lot of S'es have this issue and it often relates to the plug on the power steering pump, have you had any experience with that?
Old 04-26-2012, 10:07 AM
  Recommend this thread for the PelicanWiki    Reply With Quote #3 (permalink)
kuehl's Avatar
Yes, the S had a recall a "D" suffix pump, pressure switch.
Don't recall if the switch is normally open or closed.
Try disconnecting the switch at the pump.
Old 04-26-2012, 10:56 AM
  Recommend this thread for the PelicanWiki    Reply With Quote #4 (permalink)
mhariush's Avatar
There has been some rewire-ring on my car, a new wire that goes from the connector plug in the engine compartment in front of the fuse box that leads down to the steering pump and into the fuse box. Could this have anything to do with the recall issue?
Old 04-26-2012, 10:59 AM
  Recommend this thread for the PelicanWiki    Reply With Quote #5 (permalink)
one of gods prototypes
bell's Avatar
guys if your a/c fuses are popping you need to measure the amperage draw of the compressor. it should only pull about 4 amps, I've seen 2 this week with same issue, one was pulling 10 amps, the other 20.....you'll want to replace the magnet assembly on the compressor If that's the case....
I love speed, I love noise, I love competition and if I wasn’t still a fan I wouldn’t be here.
www.germanexcellence.com
Old 04-26-2012, 04:51 PM
  Recommend this thread for the PelicanWiki    Reply With Quote #6 (permalink)
Now Available for Ordering:   101 Projects For Your BMW 3 Series 1982-2000  [more info]
mhariush's Avatar
Thanks, I'll check that when I get a chance. What surprises me is that this is a new rebuilt compressor, I would have thought all parts had been replaced and fixed...
Do you have any experience with this Steering Pump switch issue that I've read about for the S?
Old 04-26-2012, 04:54 PM
  Recommend this thread for the PelicanWiki    Reply With Quote #7 (permalink)
kuehl's Avatar
The simplest way to check if the clutch coil is fried is to use an ohm meter.
If its toasted its because the compressor overheated.
And, when coils fry the pulley bearing sees the heat as well hence the grease
viscosity drops, and on severe toasting the clutch hub's rubber cooks as well.
Compressors overheat from lack of either refrigerant or oil flow in most cases.
Before you toss new coil or clutch assembly on the compressor its wise
to disassemble it and inspect the bores, pistons and wobble plate as in
most cases they can be damaged from lack of oil flow.
Old 04-27-2012, 02:22 AM
  Recommend this thread for the PelicanWiki    Reply With Quote #8 (permalink)
mhariush's Avatar
Thanks Kuehl,
I'll try and get to check this over the weekend, but as I mentioned in the previous post, this is a new refurbished compressor that I just had installed, like 2 weeks ago so I would be surprised if it had a fired clutch or coil.
Old 04-27-2012, 09:46 AM
  Recommend this thread for the PelicanWiki    Reply With Quote #9 (permalink)
mhariush's Avatar
The coil and clutch are good. The AC system runs with a larger fuse (10amp vs original 7.5), could the answer be as simple as the new compressor uses more power?
Old 05-01-2012, 10:42 PM
  Recommend this thread for the PelicanWiki    Reply With Quote #10 (permalink)
kuehl's Avatar
No. Most coils are 3-3.5 ohms nominal. Once the coil gets the correct voltage and amps it will only draw so many amps, such as 12 volts / 3 ohms would be 4 amps. Unless there is something else in the circuit that is consuming the power or preventing it to flow.
What was the issue or symptoms with the system prior to replacing the compressor?
Old 05-02-2012, 02:55 AM
  Recommend this thread for the PelicanWiki    Reply With Quote #11 (permalink)
mhariush's Avatar
When I got the car it had a damaged head from a timing belt failure so I rebuilt the engine and pretty much swapped out for a new compressor without playing with the old, as the previous owner said the ac didn't work. Didn't ask any more questions.
Old 05-02-2012, 09:17 AM
  Recommend this thread for the PelicanWiki    Reply With Quote #12 (permalink)
kuehl's Avatar
Whom did the evacuation, charge and test?
Type or refrigerant oil used and amount added?
Type of refrigerant used and amount added?
Old 05-02-2012, 09:31 AM
  Recommend this thread for the PelicanWiki    Reply With Quote #13 (permalink)
mhariush's Avatar
My mechanic did the installation, evacuation and test and the compressor came filled with PAG oil from the re-manufacturer for R134A freon.
Old 05-02-2012, 09:33 AM
  Recommend this thread for the PelicanWiki    Reply With Quote #14 (permalink)
kuehl's Avatar
Have you discussed this with your mechanic?
Old 05-02-2012, 09:36 AM
  Recommend this thread for the PelicanWiki    Reply With Quote #15 (permalink)
mhariush's Avatar
yes, he insist on the AC control units being damaged, I now have three of them. All of them work on my other 87 NA and don't blow a fuse there and they all work on my S as of now with the higher amp fuse.
Old 05-02-2012, 09:42 AM
  Recommend this thread for the PelicanWiki    Reply With Quote #16 (permalink)
Custom User Title
mikepellegrini's Avatar
While I've got you - this is an allied question.
What's the precise procedure for flushing? You're not supposed to flush the expansion valve? Short of disassembling the dash, I can't see any way to flush the system with that out of the circuit.
And how is this for a flush solution?: https://www.ackits.com/pc/200011/Flush/200011+-+Hecat+Safe+Flush+%28.5+Gallon%29
Any other recommendations?
83 944 NA - Black on black
86 951 - Red
97 Ford Expedition
He who hesitates is lost.
Old 05-02-2012, 12:03 PM
  Recommend this thread for the PelicanWiki    Reply With Quote #17 (permalink)
Copyright ©2000 - 2013, vBulletin Solutions, Inc.
Copyright 2011 Pelican Parts - Posts may be archived for display on the Pelican Parts Website -    DMCA Registered Agent Contact Page
