A/C Conversion R134a
Is there a good thread with pictures on how to convert the 944 series to R134a? I am looking for a more detailed thread that can show me exactly what O Rings need to be changed out as well as trying to change the compressor oil.
I remember a couple of your recent posts. A little background...
You mentioned your mechanic replaced your compressor because the clutch was dragging. In another you mentioned you wanted to wait until your uncle with all the tools could help. There are many DIYs on converting R12 to R134a. The best information to use is the Porsche conversion info found on FRWilks site: A/C R134a Here is a picture of where most of the "O" rings are located: http://forums.pelicanparts.com/uploa...1335573448.jpg Pelican has a conversion kit I bought. Many parts and valves. 944 Not listed but it works. Pelican Parts - Product Information: 55-9807-901-M325 You can get a large or small kit of "O" rings at AutoZone. Griffiths (member kuehl) AC web site has a lot of information on conversion. Specifically if you do not have to replace all "O" rings if the line is not opened. Read basic steps to convert.... AIR CONDITIONING HELP HOME PAGE,a/c,ac,air,air conditioning,barrier hose,Behr,Bosch,compressor,compressors,condensers, condenser,condensors,drier,driers,dryers,evaporato r,evaporators,freon,Griffiths,improvements,Kuehl,N ippondenso,Porsche,r12,r134a,San If your clutch/coil was defective you may have to do a complete flush and cleanout. Recent post by kuehl http://forums.pelicanparts.com/6714622-post8.html I use PAG-46 nothing thicker (AutoZone), similar to the Porsche recommended ND-8 oil. Just some basics to consider. GL John |
Evap to compressor #10,
Compressor to Condenser #8 Condenser to drier #6 Drier to exp valve #6 Exp valve to evap #8 If the vehicle is R12 (used mineral oil) you can use Ester without any oil compatibility issues. If you want to use PAG you should liquid flush the system with ac flush (you don't flush compressors or driers) lines, condenser, evap with exp valve removed. Can't mix PAG with mineral oil or PAG with ester. There are some mfg's of PAG's that claim you can, we avoid them. |
I like that picture above and it looks like most of those o rings will be replaced when I drop the compressor to change out the oil. What are the hardest o rings to get to? Are they all in the engine bay? |
| All times are GMT -8. The time now is 09:13 AM. |
