Hood strut mount broken
Trying to replace a worn hood strut last weekend when one of the ball mounts on the body broke free and disappeared. Where can I find a replacement and how does it attach to the body?
Old 03-25-2011, 01:44 PM
P944GUY's Avatar
welded...they don't make them anymore..I've tried ordering them for my 924 turbo hood...call a junkyard
Beer Cigars and a 10mm socket...
Old 03-25-2011, 07:04 PM
In the Fires of Hell.....
kdjones2000's Avatar
I had this happen to mine as well. I found the old ball and welded it back in - not much fun.
Gotta love the reliability of these things....
Keith
PCA Instructor: '88 951S - with LBE, Guru chips, 3Bar FPR, 1.3mm shimmed WG, 3120 lbs, 256 RWHP, 15 psig boost
Old 03-25-2011, 08:12 PM
Thanks. Prop rod it is then. At least the DPO included an aluminum tube the right size with the car.
Old 03-25-2011, 08:35 PM
Go to the link below and in "FIND" type Mounting Ball Studs. They are on catalog page 1187. Hope this helps.
McMaster-Carr
Cheers,
Larry
Retired USAF and Civil Service,
1985.5 NA Graphite Metallic, A never ending work in progress,
1992 968 Horizon Blue Cab "New Toy"
Old 03-25-2011, 08:45 PM
Capt Squid's Avatar
Ditto on Mcmaster-Carr. They have a ball with a stud and nut that works great.
Jim Richmond
944 Spec race car, SoCal NASA & POC
01 Boxster S
Old 03-25-2011, 10:28 PM
Would you happen to remember which one it was specifically that works?
86 951 blk
Old 04-14-2012, 12:46 PM
Capt Squid's Avatar
My McMaster Carr order history only goes back two years so you will just have to measure the diameter of your existing ball.
IMHO McMaster is hands down the best industrial supplier on the planet.
Jim Richmond
01 Boxster S
Old 04-26-2012, 10:05 PM
Garage Helper
Cocacolakidd's Avatar
Send a message via Yahoo to Cocacolakidd
I measured the diameter of my balls and they are not the same - Plus one hangs slightly lower than the other...
78-924 traded for 80-931 traded for 84-944 traded for 85.5-944 (7th one now).
UAV-M1 (Urban Assault Vehicle - Model 1)
Bless the lowered, and pass the nitromethane.
Pedal to the metal till you see the gates of hell then brake
NLA - No longer available is a four letter word
Old 04-26-2012, 11:01 PM
89-944NA's Avatar
Location: In a dumpster behind Albertson's in Los Angeles County
Send a message via Yahoo to 89-944NA
+1 on McMaster-Carr, and I have one located just three miles from me....just about everyone there knows me by name....flywheel bolts, pressure plate bolts, just about every nut, bolt, stud, sealant, electrical connection, etc. you use on these cars is available there....and you can get a box of 25 on most bolts for the price of 8 or 9 bolts elsewhere
1989 944 NA Glacier Blue - SOLD IT
1989 944 S2 Alpine White T-Boned (totaled) by a lady dressed in a CLOWN costume (RIP ) Apr 89 - Mar 08
1988 944 Turbo S Silver Rose Metallic, K27/6, Vitesse MAF, Tial 38mm DP WG
Semper Fi
Old 04-27-2012, 01:33 AM
89-944NA's Avatar
mine are large and brass
Semper Fi
Old 04-27-2012, 01:35 AM
Garage Helper
Yes if you need something ordinary they have it - plus they have all of the hardware that others do not have, the un-ordinary stuff - but to have a store just down the street from you, well that's to much luck...
Old 04-27-2012, 02:04 AM
89-944NA's Avatar
The Santa Fe Springs location is just about a 10 minute drive....I love it!!! Need to make a new wiring harness? They have the same plastic sheathing that Porsche uses...Gotta be the best ever hardware and supply ever!!!!
Semper Fi
Old 04-27-2012, 01:15 PM
... aw man did I miss the open call to measure up? Are we still measuring up? Am I too late?
86 951 blk
Old 04-27-2012, 03:32 PM
