Does the A/C compressor wire connect to the wire in this rectangular plastic sheath?
Proprietoristicly Refined
My single AC 12 volt wire is mounted along the inner frame to the AC compressor---just close enough for the AC compressor coil wire to connect.
I cannot positively say your connector if for the AC. You may have to connect the battery and test for 12V at the connector with the AC switch ON. (Key ON) John
1988 924S 68K + 1987 924S 122K DD |
Thanks John, I'll give it a try.
