-   -   Swapping seat backs? (http://forums.pelicanparts.com/porsche-924-944-968-technical-forum/674918-swapping-seat-backs.html)
James Chimney 04-30-2012 01:57 AM
can you swap the seat backs on a 85.5 944? the drivers side bolster is worn and if I could I would like to swap it with the passenger side till I recover or replace.
thanks.Swapping seat backs?
Jrboulder 04-30-2012 05:42 AM
can you swap the seat backs on a 85.5 944? the drivers side bolster is worn and if I could I would like to swap it with the passenger side till I recover or replace.<br>
The seat backs are the same left and right.
James Chimney 04-30-2012 12:33 PM
how hard, do they have to come out?
Jrboulder 04-30-2012 01:19 PM
I've only done it out of the car. its like 6 6mm allen head screws for each seat and an electrical connector for the drivers side.
John_AZ 04-30-2012 02:10 PM
How does the seat back release work on the inside?
John
Jrboulder 04-30-2012 02:38 PM
John
The late seats have a realese on both sides. It's pretty handy.
John_AZ 04-30-2012 04:27 PM
ahhh, and the 924S has the early style.
John
mikepellegrini 04-30-2012 05:22 PM
It's almost do-able in the car. Maybe. The problems would be on the inside next to the torque tube tunnel.
You have two Phillips head screws to take off the plastic covers on each side, then two (I think) 13mm bolts per side. The seat back release has a circlip you pop off (on both sides), then that comes off the shaft. Then the seat back just pulls out.
I just exhanged the seat backs on both my cars for the same reason as you. I did it outside the car because I was installing them at the same time, but if I had it to do all over, I'd try exchanging them while in the car.
It's always been a royal PITA for me every time I've tried to switch seats in a 944. Taking them out is a 5 minute operation, but for some reason, getting them back in is always problematic.
