Order Online or Call:
888-280-7799
McAfee SECURE sites help keep you safe from identity theft, credit card fraud, spyware, spam, viruses and online scams
Porsche | BMW | Mercedes | Audi | Volkswagen | Saab | Volvo | Mini
  Search Pelican Parts:
View Cart | Project List | Order Status |  Help
Volhv's Avatar
Scored cam lobe
Took the cam tower apart to reseal, and paint it, and found this.
Other than potentially wearing the lifter a bit faster, so you guys think it would be fine to just throw back in? Pulled the head and tower off a wrecked 85.5
Absolutely no oil varnish on it, and the lifter look really good, better than the one that was on my car (full of gunky oil).
The part number is 944 105 155 9R, so I guess it's a late one.
Old 04-30-2012, 12:15 PM
  Recommend this thread for the PelicanWiki    Reply With Quote #1 (permalink)
Sanity Seriously in Doubt
Which way does it turn?
I don't think its a problem, belts are a bigger problem. Its been in there for more than 20 years and it still works so...
Old 04-30-2012, 12:56 PM
  Recommend this thread for the PelicanWiki    Reply With Quote #2 (permalink)
unindicted co-conspirator
looneybin's Avatar
Does it have a ridge that is above the face of the lobe, or is it totally recessed into the lobe.
If no ridge, then it's likely OK
'86 944 - Wilks PP2, strut brace, harness bar, M030 sway bars, 200# springs, koni adj, throttle cam, K&N filters, momo wheel & shift knob - faster in the twisties than a mustang
'78 Fiat Spider
'01 Dodge Durango 4x4 (family truckster)
Old 05-01-2012, 08:27 AM
  Recommend this thread for the PelicanWiki    Reply With Quote #3 (permalink)
Volhv's Avatar
No ridge, just recessed.
It's on the down-stoke, so it's the side the opens the valve.
I wonder how that could have happened, maybe at one point in time there was some debris in the oil.
It should be fine, The top of the lifter looks normal. It just bugs me to install something that has obvious damage.
Old 05-01-2012, 02:33 PM
  Recommend this thread for the PelicanWiki    Reply With Quote #4 (permalink)
i have pulled many cam towers and one thing i always look for are extra bolts. it seems that they might come off the tool when removing or perhaps they back out after being installed . i change the inside bolts because i think the washers may be compromised. i have removed bolts without washers (the washers are captured) . back to your ? most likely a cam bolt did the damage.
Old 05-03-2012, 06:42 AM
  Recommend this thread for the PelicanWiki    Reply With Quote #5 (permalink)
Copyright ©2000 - 2013, vBulletin Solutions, Inc.
Copyright 2011 Pelican Parts - Posts may be archived for display on the Pelican Parts Website -    DMCA Registered Agent Contact Page
