Go Back   Pelican Parts Technical BBS > 1- Porsche Technical Forums > Porsche 924/944/968 Technical Forum
North Coast Cab's Avatar
944S2 DME Pin-out Diagram
Anyone have a 944S2 DME pin-out diagram?
Swapped an S2 motor into the race car and am unable to get spark.
Made necessary 14pin connector changes
Installed Ignitor and wiring
Verified good crank sensor, DME, Ignitor, Coil etc.
No factory wiring other than the engine harness.
Power to coil
Fuel
Injectors firing
NO SPARK
Thanks!
1985.5 944 GTS
Old 05-04-2012, 07:22 AM
  Pelican Parts Technical Article Directory    Reply With Quote #1 (permalink)
Eric
Here you go....
I had to derive this myslef using in part a 964 DME assignment - they are very similar.
Eric
Old 05-06-2012, 01:47 AM
  Pelican Parts Technical Article Directory    Reply With Quote #2 (permalink)
Thanks, as suspected no power.
The 2.5NA has a 4 pole connector off the wiring harness by the DME which for the most part controls the tach. The S2 has a 14 pin connector which requires power to pin #5 to feed the DME. Looking good for solving the issues......except there is no pin in the #5 spot on the 14 pin connector......
Digging deeper. Need to figure out the wire coming off the #18 pin on the DME and follow it back through the harness.
1985.5 944 GTS
Old 05-06-2012, 10:13 AM
  Pelican Parts Technical Article Directory    Reply With Quote #3 (permalink)
That Guy
Techno Duck's Avatar
For future reference..
Jon - San Diego PCA #516
1988 Granite Green 911 3.4L
2017 Reflex Silver Mk7 GTI
Past worth mentioning - 1987 924S, 1987 944, 1988 944T with 5.7L LS1, 1997 E36 M3, 2003 E39 540i
Old 05-06-2012, 10:36 PM
  Pelican Parts Technical Article Directory    Reply With Quote #4 (permalink)
Eric
Now why couldn't I find that when I went looking for it. That page (7 and 8) isn't part of my Vol 1A. Have you got page 24/28 - 7 as well??
Eric
Eric
Old 05-07-2012, 05:48 AM
  Pelican Parts Technical Article Directory    Reply With Quote #5 (permalink)
That Guy
Page 7 is a two part fold out like the wire diagrams..
Old 05-07-2012, 08:09 AM
  Pelican Parts Technical Article Directory    Reply With Quote #6 (permalink)
Now Available for Ordering:   101 Projects For Your BMW 3 Series 1982-2000  [more info]
Thanks!
Where would I find the wire designation color chart for the DME cable?
1985.5 944 GTS
Old 05-07-2012, 10:50 AM
  Pelican Parts Technical Article Directory    Reply With Quote #7 (permalink)
That Guy
You will need to look at the DME / Engine wire harness schematic. I can scan those also if you need when I get home.
Edit - Forgot to add, let me know what schematic you need the scan for.. your '85.5 944 or the S2 harness.
Old 05-07-2012, 01:46 PM
  Pelican Parts Technical Article Directory    Reply With Quote #8 (permalink)
Eric
Eric
Old 05-08-2012, 05:37 AM
  Pelican Parts Technical Article Directory    Reply With Quote #9 (permalink)
Copyright 2017 Pelican Parts LLC - Posts may be archived for display on the Pelican Parts Website -    DMCA Registered Agent Contact Page
