-   -   924 Eliminate Sensors (http://forums.pelicanparts.com/porsche-924-944-968-technical-forum/678284-924-eliminate-sensors.html)
batsong 05-16-2012 02:52 PM
Hi. This is my first post as I have been able to get the questions I've had regarding my '81 924 NA answered by searching old threads. Suffice to say, there is a knowledgeable group here concerning these cars!
I was wondering if anyone has ever been able to eliminate the O2 sensor and throttle switches on their 924. Right now, I have the wires on the bottom throttle switch closest to the radiator (off idle switch?) jumped together in order to get the idle steady and to get rid of a gentle surge @ ~ 3k rpm.
Any thoughts?
924RACR 05-17-2012 05:29 AM
You kinda need those. You should be addressing the root cause, instead of screwing up the car. Most likely you have vacuum leaks...
batsong 05-17-2012 07:27 PM
Sorry to waste your time. I'll try not to "screw up the car" for your sake.
Goodbye.
Rasta Monsta 05-17-2012 08:54 PM
There's lots of knowledge here, but I don't want to listen to it.
