Tallest wheel setup for mpg.
I'm looking at doing the v8 swap into a 87 944 but I'm trying to figure if I can get a good cruising rpm. So what is the tallest rear tire I could run? I'm currently running 255/17/40, Could I move to 55's?
Remember that when you increase the diameter beyond stock (OEM) wheel/tires, you'll have innacurate speedo readings. Bigger tires, faster car for an indicated speedo reading.
you would be far better off swapping out the trans
Your 255/40-17's still match the overall diameter of the original tire - of which the system is balanced to. If you move to a different size tire like 255/55-17's the whole system will be off, including the speedometer rate, over-steer and others. The next question is will it fit under the wheel wells without rubbing - maybe no. Stick with known good sizes...
A turbo transaxle with the N/A 5th gear swap will give you a 2000 RPM @60 MPH.
Speedy:) |
Is there any final gears longer than the 5th in a 944 n/a?
Yes ,the 0.68 5th from a '80-'82 audi 5000 diesel .If anyone can source these for a resonable price i'm also interested.
5th gear options, Audi? |
You would be better off buying a Honda as a daily drive if you are worried about fuel bills....
http://forums.pelicanparts.com/uploa...1337291843.jpg |
| All times are GMT -8. The time now is 07:14 AM. |
