Porsche Crest '77 924 won't turn over
First I'd like to say that my 77 924 started today, I backed it out of the driveway and parked it on the street. 4 minutes later I go to start it and it doesn't turn over.
I've done plenty of trouble shooting and it's not the Battery, when I try to turn it over I hear a tiny spark sound in the enginebay, but no noise from the starter.
Should I be looking for a loose wire. Does anyone have any suggestions, or something simple I might have missed?
Old 05-19-2012, 02:28 PM
check the terminals on the ignition coil. mine had come loose while driving and i sat on the side of the road for 2 hours before i figured it out. just had to clean and tighten a nut.
Black 1984 944
2003 Land Rover Freelander SE3
Old 05-19-2012, 03:39 PM
redstrosekNic's Avatar
The coil has nothing to do with the car turning over.
If you've ruled out a bad battery, check the connections; especially grounds. Follow the positive cable and make sure it is connected properly to the starter. Once you get the car fired up, make sure it is charging as well (bad connections are a recipe for not charging or starting).
Good luck!
Dustin
Old 05-20-2012, 10:18 AM
So I go out to the car today after letting it sit for 24 hours.. And it was rough at first but it started and ran as usual after that. And started again...
I think a valid theory is that a ghost is living in the electrical system
Old 05-20-2012, 11:19 AM
Dave Colangelo's Avatar
you may have an intermittent starter relay. I had a similar problem. You may also be arcing the battery to the hood. A common solution for that is to put a piece of cardboard over the battery to keep it from doing that. As for the relay I would get under there, pull the wires off and clean the terminals with a good wire brush and your rust remover of choice. Corrosion can get these things real bad and cause this very issue.
Regards
Dave
'78 911SC Targa (Back In Action!)
'87 944 (college DD)
'88 924s (high school DD)
Old 05-20-2012, 11:56 AM
Tags
924 , starter , turn over , wiring
