RPMS Hover
Sometimes my RPMS will hover or decrease very very slowly when I push the clutch in. It happens seldom and randomly, though perhaps moreso on warmer days? Any ideas? Thanks
That Guy
What year is your car? If 85.5+, the first thing is to check the idle is set correctly.. here are some good directions..
http://www.clarks-garage.com/shop-manual/fuel-08.htm
Jon 1988 Granite Green 911 3.4L 2005 Arctic Silver 996 GT3 Past worth mentioning - 1987 924S, 1987 944, 1988 944T with 5.7L LS1 |
The first thing I thought of was a possible vacuum leak, but you said clutch, not brake right? The lines that operate the clutch should have no impact on idle speed, inless the brake booster vac line is somehow involved?
86NA944 |
Yeah, when the clutch is in. It is happening
constantly now that it is warmer in the 80s now |
Throttle cable sticking?
Could it just be the gauge?
When I push in the clutch the tacho drops to idle revs, until I engage the new gear. Could the gauge simply be sticky?
1980 911 SC Metallic Blue Euro spec, 'Greta'; 1986 944 Euro spec Light Bronze Metallic, 'Sabine II' 1986 944 NA Euro spec Guards Red 'Sabine I' - RIP, gone but not forgotten 'Hell is previous owners.' (anon.) Last edited by CatsEyes; 05-25-2012 at 06:19 PM.. |
