cjpacitto's Avatar
944S exaust manifold ring gasket question
The 944S & S2 use rings instead of normal exhaust manifold gaskets. Do you just stick these in there and bolt the manifold on or is there any additional sealant required in there?
Old 05-28-2012, 12:49 PM
Porsche 944S Club Sport
guru944's Avatar
Send a message via AIM to guru944
No sealant required...
However you could use "Ultra copper sealant just before bolting on the headers...
Guru944
2006 955 Cayenne S Titanium Series - Marine Blue, 1987 Porsche 944S Club Sport.
1987 Buick Turbo-T Lightweight "Great White", +500HP, TA49 Turbo.
http://www.blackbirdmotorsports.com, 944/951/968, 911 and 955/957 Performance Solutions.
Thank you Lord, for your Loving Kindness, Tender Mercy, and Grace. Only You are Faithful.
Old 06-01-2012, 08:43 PM
89-944NA's Avatar
Location: In a dumpster behind Albertson's in Los Angeles County
Send a message via Yahoo to 89-944NA
Make sure the groove that the seal ring goes into is clean. You don't need to put sealant on them, they crush when the two pieces are mated together to form the seal. Or you can buy the aftermarket copper gaskets from Lindsey, they are reuseable, where in most cases the sealing rings aren't.
1989 944 NA Glacier Blue - SOLD IT
1989 944 S2 Alpine White T-Boned (totaled) by a lady dressed in a CLOWN costume (RIP ) Apr 89 - Mar 08
1988 944 Turbo S Silver Rose Metallic, K27/6, Vitesse MAF, Tial 38mm DP WG
Semper Fi
Old 06-01-2012, 09:35 PM
