Go Back   Pelican Parts Technical BBS > 1- Porsche Technical Forums > Porsche 924/944/968 Technical Forum
Send a message via ICQ to GAKFU Send a message via Yahoo to GAKFU
944 clutch pedal stuck down
When ever I push the clutch pedal down it stays down. I can put my foot behind the pedal and pop it back up. Any ideas??
Old 06-04-2012, 04:58 PM
  Pelican Parts Technical Article Directory    Reply With Quote #1 (permalink)
Self-Proclaimed Newb
Brozoar's Avatar
Send a message via Skype™ to Brozoar
Either air in the lines, or more severely, need to replace the clutch master AND slave cylinders. I'm assuming it's not the return spring, but start checking there. If that's good, try bleeding the system, I guess. Clutch and brakes use the same fluid reservoir.
All else fails, it's your cylinders.
Current: 1986 944 Turbo - Sapphire
Past: 1983 944NA - Black (RIP)
1985.5 944NA - Guards Red (in purgatory)
1985.0 944NA - Maraschino Red (traded for a Volvo 244 )
Old 06-04-2012, 05:28 PM
  Pelican Parts Technical Article Directory    Reply With Quote #2 (permalink)
bleed the clutch system.
Look for leaks out of the clutch slave cylinder (near starter) or from the clutch master cylinder.
If in any doubt, but both replacement units.
Also, purchase a Motive Powerbleeder, a great tool that makes your life easier.
1983 Porsche 944 2.5Ltr
2004 Holden Monaro 5.7 Litre
1976 Triumph Dolomite Sprint 2L 16V
1999 Daewoo Lanos (everyday car) 1.5L
Old 06-04-2012, 05:29 PM
  Pelican Parts Technical Article Directory    Reply With Quote #3 (permalink)
Poorscheboy's Avatar
This spring mine did this, I had a leak in the slave. Replaced it, did a bleed and I'm back in business.
85.5 PORSCHE 944
87 PORSCHE 944S
Old 06-05-2012, 03:03 AM
  Pelican Parts Technical Article Directory    Reply With Quote #4 (permalink)
Parrothead member
VINMAN's Avatar
Most likely your clutch master cylinder. Look under the dash where the rod comes through to the pedal. Check for any fluid leaking.
Vinny
Red '86 944 '02 Dodge Ram, 3500 Diesel 4x4 Dually, '07Jeep Wrangler '62 Mercury Meteor '90 Harley 1200 XL
Old 06-05-2012, 03:48 AM
  Pelican Parts Technical Article Directory    Reply With Quote #5 (permalink)
Garage Helper
Cocacolakidd's Avatar
Send a message via Yahoo to Cocacolakidd
Any time when you are working on/bleeding the clutch system have the rear of the car higher than the front - The master reservoir serves both the brakes and clutch systems and the clutch part is in the front so if the clutch bleeding uses up fluid the front part of the clutch reservoir will gain air quickly - up in rear just makes the job easier.
Yes it sounds like the master clutch cyl. is leaking - most recommend that you replace both cyls. (Master and slave) while you are in there (WYAIT ).
78-924 traded for 80-931 traded for 84-944 traded for 85.5-944 (7th one now).
UAV-M1 (Urban Assault Vehicle - Model 1)
Bless the lowered, and pass the nitromethane.
Pedal to the metal till you see the gates of hell then brake
NLA - No longer available is a four letter word
Old 06-05-2012, 09:05 AM
  Pelican Parts Technical Article Directory    Reply With Quote #6 (permalink)
Now Available for Ordering:   101 Projects For Your BMW 3 Series 1982-2000  [more info]
+1 for having the rear higher than the front. Mine stuck in my driveway (car was pointed uphill), and I did all the work at the end of the driveway. It would have been much easier to bleed the clutch if it was the other way around...
Old 06-05-2012, 12:14 PM
  Pelican Parts Technical Article Directory    Reply With Quote #7 (permalink)
I had that for about a week, and only when the clutch was cold, after 15 minutes it would get better. This week everything is fine. What's that all about?
Old 06-05-2012, 12:19 PM
  Pelican Parts Technical Article Directory    Reply With Quote #8 (permalink)
I had the same problem when I bought my car... Eventually, the slave cylinder gave out. Fortunately (and unfortunately), it went out in my driveway. Went to drive the car to work one morning, stepped on the clutch, and it pulled itself to the floor and stuck.
I'd suggest you look into replacing your master and slave as well (probably the lines in between too).
Old 06-05-2012, 12:34 PM
  Pelican Parts Technical Article Directory    Reply With Quote #9 (permalink)
dang, its all only 2 years old too...
Old 06-05-2012, 12:47 PM
  Pelican Parts Technical Article Directory    Reply With Quote #10 (permalink)
You could try your luck at bleeding it first...
Old 06-05-2012, 01:00 PM
  Pelican Parts Technical Article Directory    Reply With Quote #11 (permalink)
White and Nerdy
Tervuren's Avatar
Any news?
And from my experience, I'm in agreement with the others that air has entered your clutch system.
It pretty much only gets in there if fluid leaked out, and air replaced it, simply bleeding it will be a temporary fix, but it will simply leak out again. There are lots of suggestions here of what the leak may be, probably the easiest to check is the slave cylinder next to the starter, have someone move the clutch repeatedly, and if fluid is dripping out, that is your problem. Find your leak, fix it, bleed it, and you should be good.
Jorge, Archetacky
Old 06-07-2012, 05:24 PM
  Pelican Parts Technical Article Directory    Reply With Quote #12 (permalink)
Garage Helper
Then how would one explain of the air and water in a sealed system - Not leaking, and no air entering from the outside.
The fluid used in the brake system, hydraulic brake fluid, is a Carbon Formula Fluid. We learned in Chem 101 that when you heat (Close to and even boiling) that when the chemical equation is balanced after the energy of heat is added to one side, the air and water is added to the other side of the equation to balance the whole. A proof of how the air and water enters the hydraulic system even though it's sealed. So even on perfect sealed systems it's best to change out the fluid every two years or so.
yeah I know, smart ass - just thought some would like to know.
Old 06-07-2012, 05:46 PM
  Pelican Parts Technical Article Directory    Reply With Quote #13 (permalink)
I wasn't listening can you repeat that? HA! Good explanation! Thanks!
85.5 PORSCHE 944
87 PORSCHE 944S
Old 06-08-2012, 03:34 AM
  Pelican Parts Technical Article Directory    Reply With Quote #14 (permalink)
89-944NA's Avatar
Location: In a dumpster behind Albertson's in Los Angeles County
Send a message via Yahoo to 89-944NA
Every two years is the recommended service interval on fluid changes. The air that enters the reservoir contains moisture, and brake fluid absorbs this moisture, thereby gradually lowering the boiling point of the brake fluid and reducing it's efficiency.
Actually, automotive braking systems are not truly "sealed" systems, they require atmospheric pressure to work properly. Those of us who have worked on "old" cars will remember the vent hole on the top of the reservoir cap, that was there to allow atmospheric pressure (air) into the system. That "open vent" of yesterday not only allowed atmospheric pressure (air) into the system, but also dirt, dust and any manner of contaminant.
Look closely at the picture, the pick is pointing at the small vent hole located on the shaft for the brake fluid level float, this vent hole is above the fluid level, under the rubber "dust cap" on the top of the reservoir cap there is also a small hole to allow in outside atmospheric pressure (air) into the system. The seal under the cap is there to keep fluid from escaping from around the cap.
So ends lesson #2 (Cocacolakidda gave lesson #1) of how air enters your braking system. Lesson #3 (if ever published) will explain how Pascal's Law applies to automotive braking systems......Sorry, I just couldn't resist.
1989 944 NA Glacier Blue - SOLD IT
1989 944 S2 Alpine White T-Boned (totaled) by a lady dressed in a CLOWN costume (RIP ) Apr 89 - Mar 08
1988 944 Turbo S Silver Rose Metallic, K27/6, Vitesse MAF, Tial 38mm DP WG
Semper Fi
Old 06-08-2012, 07:35 AM
  Pelican Parts Technical Article Directory    Reply With Quote #15 (permalink)
flash968's Avatar
the one item that seems to be ignored a lot is the high pressure hose. it starts failing from the inside out, and cannot be gauged from the outside. the hose is only supposed to last a max of 10 years. many of them are much older than that, so i'm not surprised they fail
on the 968 it is a well known failure item, and is often symptomized by a swelling at the joint. i have now sold about 200 stainless steel teflon lined hoses as a result of this problem.
Old 06-08-2012, 07:48 AM
  Pelican Parts Technical Article Directory    Reply With Quote #16 (permalink)
Toofah King Bad
Rasta Monsta's Avatar
If your master has leaked into the passenger compartment, SCRUB SCRUB SCRUB or you will have a problem.
» 1980 931 - Got boost? ♦ 1987 924S - Pro44 ♦ 1987 924S - Junkyard score «
"DETERMINATION. Sometimes cars test us to make sure we're worthy. Fix it." - alfadoc
Old 06-08-2012, 09:32 AM
  Pelican Parts Technical Article Directory    Reply With Quote #17 (permalink)
Copyright 2017 Pelican Parts LLC - Posts may be archived for display on the Pelican Parts Website -    DMCA Registered Agent Contact Page
