honerboys's Avatar
engine install with exhaust manifold attached
hey - i took the exhaust manifold off this engine before i removed it - thought maybe it could be fixed without engine removal but that was not the case - anyway can i now attach the manifold back on before installing the engine back in the car - is there enough room - the manuals i've seen say too remove the exhaust system before pulling the engine but i'm not sure if that also includes the manifold - thanks
84 928 S - SOLD
2012 Cayenne S
Old 06-29-2012, 10:33 AM
You can install the engine from either top or bottom with the exhaust header on. It's much easier to put on that way.
May wanta take out Fans and/or Radiator to give yourself a little extra room.
1987 924S with 968 Drive front to back, Bilstein Insert on mod/stock Struts, 450# Hypercoils, 28mm Torsion Bars, Weltmeister Adjustable Sway Bars, Lindsey 968 Light flywheel, Spec Stage II Clutch, ToYO RA1's, Auto Power Cage & 6 pt Harness, KLA Strut Brace, Greasy hands, heavy foot, and lots of smiles
Old 06-30-2012, 07:57 AM
Custom User Title
mikepellegrini's Avatar
We've always done it from the bottom with the exhaust header on.
You really do need to take both the fans and radiator off to get enough clearance.
83 944 NA - Black on black
86 951 - Red - SOLD 7/21
16 Ford Expedition
He who hesitates is lost.
Old 06-30-2012, 09:27 AM
honerboys's Avatar
thanks - the fans and radiator are already out so i'm good to go
84 928 S - SOLD
2012 Cayenne S
Old 06-30-2012, 12:42 PM
