944 85/1 trans mount : "yellow" vs "white"?
Anyone know the difference? ; one is a bit cheaper. I have to pay the killer crosspond postage either way.
I'm searching for 2 new mounts to try and eliminate those 27 year old ones as a cause for backlash. Yeah I know , it's probably the clutch , but...worth a try until the budget is healthier.
'81 924 , '85 944 , '78 911SC , '82 928 5.0L "They run best being run close to the ‘limit’ and done so regularly" - Grady |
Location: In a dumpster behind Albertson's in Los Angeles County
Where are you finding the "yellow" and "white" engine mounts? Who makes them? Are they $30 mounts or $150 mounts?
I doubt anyone here can be of much help with the little information supplied.
1989 944 NA Glacier Blue - SOLD IT 1989 944 S2 Alpine White T-Boned (totaled) by a lady dressed in a CLOWN costume (RIP ) Apr 89 - Mar 081988 944 Turbo S Silver Rose Metallic, K27/6, Vitesse MAF, Tial 38mm DP WG Semper Fi |
Rose Passion - P34945 - TRANSMISSION MOUNTING WHITE / WHITE - Porsche 944 1983 944 2.5 COUPE MANUAL GEARBOX, 5 SPEED > CLUTCH / GEARBOX PARTS > Diagrams Rose Passion - P34943 - TRANSMISSION MOUNTING YELLOW / YELLOW - Porsche 944 1983 944 2.5 COUPE MANUAL GEARBOX, 5 SPEED > CLUTCH / GEARBOX PARTS > GEARBOX SUPPORT
Triple T
Picked up a garage full of parts from Neumann racing...
Yellow trans mount came from their Rothmans car. White came from stock S2. Hope this helps
Certainly; makes sense that there is a performance alternative. I'll chase the whites , cheers!
