mind bogler
I have a 1983, 944 the problem that I am having is, the car will start and run until it reaches operating temp, it is likes it runs out of fuel?. things I have done are, changed fuel/dme relay, out, fuel pump and check valve, tested the fuel pressue regulator ok tested the DME (switched out with a new one) it still die's, tested the reference/speed sensors with multi tester, tach needle bounced ( not a lot but does) need to come up with new ideas and need help from anyone who has had this problem, or similar situation, any help will be appreciated.
Old 06-04-2012, 07:21 AM
89-944NA's Avatar
Location: In a dumpster behind Albertson's in Los Angeles County
Send a message via Yahoo to 89-944NA
did you check the fuel pressure damper?
1989 944 NA Glacier Blue - SOLD IT
1989 944 S2 Alpine White T-Boned (totaled) by a lady dressed in a CLOWN costume (RIP ) Apr 89 - Mar 08
1988 944 Turbo S Silver Rose Metallic, K27/6, Vitesse MAF, Tial 38mm DP WG
Semper Fi
Old 06-04-2012, 10:33 AM
Professional Bull5hiter
Outback Porsche's Avatar
Engine temp sensor (not the radiator one - the one in the head )
or maybe O2 sensor (if you have one) - disconnect it and see what happens
Jeff
83 944 Guards Red
23 718 GT Silver
Old 06-04-2012, 06:11 PM
alan6272's Avatar
My engine temp sensor would loose connection when warm and gave me a lot of grief till I found what it was.
1983 944 ,1983 V-65 magna
catalina22 sold
baja ski boat sold
my toys
Old 06-04-2012, 07:07 PM
Engine temp sensor .
Old 06-04-2012, 07:23 PM
Guru's of the 944's, thanks for all of the suggestions, and yes it not only was the temp sensor, also the DME/ Fuel relay were bad even they were new, go figure, remember always buy OEM those other after market parts are no good. thanks again
Old 06-11-2012, 08:40 AM
