alpom's Avatar
944 turbo engine rebuild 1100 rpm idle
i rebuilded the engine (everything but pistons and valves... they were in perfect state) added an msg ignition system
my rpm is always at 1100 at idle... i tried the bolt to adjust it and i can only drop it to 1000 and if i push the gaz a bit too much the car stall when i go back to idle.
what could it be... what can i do?
vacuum is at 20, all hoses have been changed for silicon hoses.
thx guys
Alfa Romeo Spyder veloce restored for SALE
Porsche Black 951 restored (engine, trany, body, etc) SOLD
Porsche Black 911 1993 race car cage not finish 3.6 (SOLD)
Porsche grey 911 1970 E (SOLD in pieces)
Old 06-10-2012, 05:22 PM
alpom's Avatar
no advice?
Old 06-11-2012, 08:15 AM
porscha
matty89's Avatar
What does ur throttle plate look like and ur idle air valve?dirty?
Old 06-11-2012, 09:40 AM
968 GUY's Avatar
Go to clarks-garage.com and read up on setting idle. There is more to it than just the screw.
87 951 all stock exc. cup II's /94 968 6-spd, lowered,17in. RUF Speedlines, M030 anti- sways/ 94 968 Tip, Cup II's, otherwise stock
Old 06-11-2012, 12:00 PM
Custom User Title
mikepellegrini's Avatar
I had the same thing when I put a new engine in my 951 and it really drove me nuts - till I figured out (by accident) that the cruise control cable was adjusted wrong.
If you have cruise control, you might check it. I spent hours and hours screwing with the throttle body adjustment, vacuum lines and the throttle return spring and a whole bunch of other stupid stuff before I figured it out.
83 944 NA - Black on black
86 951 - Red - SOLD 7/21
16 Ford Expedition
He who hesitates is lost.
Old 06-11-2012, 01:02 PM
alpom's Avatar
i went to clark garage and saw the procedure. ill try it soon.
throttle plate is like new and idle valve has been cleaned and seems to be working fine. i have another one ill try it.
cruise control is working fine but ill take a look at it.
ill look at it tomorow
thx a lot guys
Old 06-13-2012, 06:16 AM
Custom User Title
Mine, the cruise worked fine. It was just adjusted too tight (or short), so it raised the idle. To see if that's it, just loosen the adjustment on the cruise control cable (make it longer).
16 Ford Expedition
Old 06-13-2012, 06:58 AM
Is your AFM plugged in correctly? Make sure that is tight.
Old 06-13-2012, 07:04 AM
