Moaning Sound at Right Rear
Hi Guys,
For the past couple months I have an on and off moaning sound coming from right rear, lasting a couple seconds, mainly in the morning. Today I had a start that took a couple extra seconds and as I drove off the engine was chocking at acceleration and quit once. Then run fine. I am suspecting Fuel Pump without beeing sure. What do you Experts think? Your advise will be as always greatly appreciated.
1984 944 N/A Passadena Gold, No Sunroof 1971 Cuda 440-6, 4 Speed, The Last 440-6 Cuda built, Black 1971 Cuda 340, A/T, Rallye Red 1970 Cuda Ragtop, 383, 4 Speed, Triple Black |
Back from Beyond
Given your description you're probably on the right track. The fuel pump is easy to swap out, too, and good used ones are plentiful.
'88 944 Auto - project, kinda '87 944 Auto - died saving my wife '84 944 5SP - crushed under shop roof during snow storm All others GONE! |
Location: In a dumpster behind Albertson's in Los Angeles County
loud moaning from the right rear? So that's where they hid the body!!!!!
Really, sounds like your spot on with it being the fuel pump.
1989 944 NA Glacier Blue - SOLD IT 1989 944 S2 Alpine White T-Boned (totaled) by a lady dressed in a CLOWN costume (RIP ![]() 1988 944 Turbo S Silver Rose Metallic, K27/6, Vitesse MAF, Tial 38mm DP WG Semper Fi |
White and Nerdy
That is the fuel pump, but even with a new fuel pump, my early model 944 still makes that noise, and my other early model 944 made it to.
When was the fuel filter last changed?
Shadilay. |
I own the car for 3 years never changed it even though I bought a new one. I have no record from P.O. so who knows? Your question is very wise, it may be my problem.
Yes, by all means change the fuel filter. When you first turn the key to the start position do you hear that moan for just a second or two, if so, that's normal, fuel pump pressurizing...if the maoning continues and can be heard while driving, your pump may be going south.
