Porsche Crest fuel and fire but does not start
First off the car is 1987 944 NA 2.5l. I have fuel and fire but it will not start unless I pour gas into throttle body the car fires right up and purrs like a kitten for a few seconds. I got good pressure in the rail, good spark, new battery, dme relay, and a new fuel pump! When i turn the key on(but not start) I GET 12V ON BOTH PINS IN THE INJECTOR PLUG. Is 12v suppose to be on both sides? (All i seem to be getting is conflicting information on this ) Maybe no injector pulse? and if so what sensor creates/determines the pulse and how to test it
I had this car for a week and is the first Porsche i ever owned/touched. So any help is appreciated. Detailed information is greatly appreciated
Old 06-30-2012, 11:41 PM
Dane Brown's Avatar
have you checked out the Mass Air Flow (MAF) the little box in the middle of the intake hose and the air box?
Old 06-30-2012, 11:49 PM
Dane Brown's Avatar
also on the top of the throtle body there is a idle screw try messing with that. un screw it all the way then screw it in once it hits the rubber ring on the screw turn about 2 or 3 full turns then try to start it
Old 06-30-2012, 11:52 PM
If the ignition is on, but the engine is not running, there will be 12 Volts on both sides of the injector. The DME computer drops one of the legs to ground to fire the injectors.
I highly recommend Clark's Garage Home Page and the Garage Shop Manual for troubleshooting procedures.
Good luck, George Beuselinck
Old 07-01-2012, 06:43 AM
