-   -   exchaust questions.. (http://forums.pelicanparts.com/porsche-924-944-968-technical-forum/68603-exchaust-questions.html)
snappy 05-15-2002 12:51 PM
I have a 86 n/a 944 that is in excelent shape. inside and out.. the time has come for my "baby" to get a new exhaust. I live in san mateo in california. I am new to the US and dont know where to go or not to go.. I have a couple of questions regarding this.
1: Where should I go to get a new exhaust. I have spend hours online and in the yellow pages but nothing and nobody stands out, as beeing any good. Does anyone on this list have any info and/or experiance working with somone that is near me.
2: If I decide to put a test pipe in and bypass the CAT conv. what will happen if the CHP sees that I did that. will I get a slap on the wrist and a fine?
3:I am not looking for an exhaust that is going to make my car sound like a 69 Chev v8. If I remove the CAT conv. would that make it louder?
All help would be really appreciated . and please excuse the questions if they seem a bit dumb ;) . tia
AFJuvat 05-15-2002 02:32 PM
Bursch makes a good aftermarket exhaust. - you can order it here at pelican. It wil make your car a little louder.
They aren't too difficult to install yourself. Just a simple matter of taking out the old one and putting in the new one.
Just soak the nuts/bolts in penetrating oil - PB blaster seems to work the best. When I did mine, I sprayed them down the night before , so they soaked all night - they came right off after that.
Yes, removing your cat or bypassing it is illegal, and you will be fined if you are caught.
AFJuvat
944S Boyeee 05-16-2002 10:40 AM
Did you all know that is ISN'T illegal to remove your CAT Conv. in Canada, as long as the car is 89 or earlier??
I took the Cat of my Sidekick (1989) and it gets passed every year.
Should I take the Cat off the Porsche?? Any advantages?
944S Boyeee
AFJuvat 05-16-2002 10:49 AM
It will be a little louder, Also you'll gain a few more horsepower. You will not see a significant difference unless you were to change to a better exhaust system.
AFJuvat
944S Boyeee 05-16-2002 11:07 AM
Thanks Mike -
.....you can tell when Mike is back, cause the answers come fast and informed!!
944S Boyeee
scottmandue 05-16-2002 12:45 PM
In California you will have to smog test your car when you renew the registration (is it every year or every other year?) Anyway I think you need the CAT to pass. Some of the guys on this board have done exhaust mods with a hi flow CAT and have reported that they can get a pretty loud exhaust note with a CAT in place.
snappy 05-16-2002 02:45 PM
Thanks for the replies. I was thinking of doing the MSD ignition upgrade but with the exhaust as well. As far as I know, most of the exhaust mods out there end up sacrificing low-end torque, which in turn the MSD improves. So we would have to see what it does on real life. Man I hate it when things look good on paper. But you don’t know if it would work as good in the field ;)
