dmacis333's Avatar
Send a message via Yahoo to dmacis333
1984 944 Break Rotor
I have spent hours and hours attempting to find anyone with any images or step by steps to get off the rotors off this car! Is there anyone out there with this secret knowledge?
Old 07-03-2012, 09:04 AM
fiat22turbo's Avatar
Remove the caliper.
Remove the center nut behind the dust cover to remove the hub and bearings.
Remove the bolts and nuts in the hub that hold the BRAKE rotor to the back of the hub.
the bolts and nuts are in the webbing of the hub and can be clearly seen from the backside once the hub is off.
Replace rotor, clean everything, loctite the mounting bolts, clean and pack the bearings with fresh grease (replace the bearings if they are showing signs of wear)
Lots of info found here: Clark's Garage Shop Manual Index and in the Hayne's manual, not too mention the Factory Service Manuals
Hope this helps.
Stefan
Portland, OR
1979 Porsche 924 Carrera GTS (clone-ish)
1988 Porsche 944 Turbo S (Silver Rose)
Old 07-03-2012, 10:29 AM
Both have retaining screws you must take out
the rear's you might have to pull in the emergency brake shoes to clear the inside lip.
hope this helps
Old 07-03-2012, 11:49 AM
Toofah King Bad
Rasta Monsta's Avatar
Time for someone to pony up for a manual.
» 1987 924S Turbo - Got Boost? «
"DETERMINATION. Sometimes cars test us to make sure we're worthy. Fix it." - alfadoc
Old 07-03-2012, 12:17 PM
89-944NA's Avatar
Location: In a dumpster behind Albertson's in Los Angeles County
Send a message via Yahoo to 89-944NA
+1 Yup
1989 944 NA Glacier Blue - SOLD IT
1989 944 S2 Alpine White T-Boned (totaled) by a lady dressed in a CLOWN costume (RIP ) Apr 89 - Mar 08
1988 944 Turbo S Silver Rose Metallic, K27/6, Vitesse MAF, Tial 38mm DP WG
Semper Fi
Old 07-03-2012, 12:38 PM
dmacis333's Avatar
Yep bought the service manual last night and dumb luck we finally got the dust cap off to expose the 6mm bolt. Thanks for all the help!
Old 07-04-2012, 06:56 AM
Tags
1984 944 porsche
