-   -   Whats causing my engine to overheat? HELP PLeaSe! (http://forums.pelicanparts.com/porsche-924-944-968-technical-forum/687069-whats-causing-my-engine-overheat-help-please.html)
jonvibar 07-03-2012 08:18 PM
Im from the Philippines, i have a honda vtec 1998 model. Its always overheating.
I already changed the radiator cap / replaced the thermostat sensor / took out the thermostat / had the radiator cleaned / the fan is working well / radiator fluid are sufficient / engine oil is in good level / I even had the head reface and changed the head gasket , but the car still overheats! what could cause this? :confused:
Guest765 07-03-2012 08:46 PM
Lol, what?
POPS 83 944 07-03-2012 10:06 PM
He should have bought a 944, then his Honda could have been his weekend car and the 944 as his DD!!
1982_928 07-03-2012 11:39 PM
The fact that it is a Honda and it should be parked under a tree somewhere could be part of it..
We.Dont.Like.Honda's.
Go to a Honda forum. We specify in Porsche's.
ernie9944 07-04-2012 04:30 AM
We.Dont.Like.Honda's.___No need to be sarcastic & rude :eek:
Jonvibar----You,ll have a better chance to get the rigth answer to your overheating problems if you ask on a HONDA specific forum,good luck.:)
