-   -   speed & reference sensor mounting (http://forums.pelicanparts.com/porsche-924-944-968-technical-forum/689102-speed-reference-sensor-mounting.html)
petrolhead611 07-16-2012 01:49 AM
The replacement enging that I have obtained has some metal missing from the block around the dowelled mounting hole but the thread is all there. Placing the dowel from my old engine into the the new one leaves the dowel slightly too expand to enter the sensor mounting bracket hole. Should I fit the dowel into the sensor mounting bracket then offer it up to the block? Or should I relieve the bracket hole enough to accomodate the dowel at its current size within the block ?
Then I can use plastic metal on the block to fill the space left by the missing metal
phoenix_iii 07-16-2012 07:23 AM
How about a pic, and re-write your paragraph mess so it is a bit easier to understand?
petrolhead611 07-17-2012 01:51 AM
Apologies for my two typing errors caused by extreme haste, but otherwise English comprehension lessons are surely available on other web-sites .
v2rocket_aka944 07-17-2012 11:46 AM
You can't call out a British person for poor English, it's not technically possible.
That said, howabout cutting a slit in the dowel to shrink it down a bit?
v2rocket_aka944 07-17-2012 11:47 AM
petrolhead611 07-18-2012 02:31 AM
Thank you for the suggestion to widen the slit in the dowel.
